AMD targets Atom microservers with Opteron X-Series
May 29, 2013 | 11:21
Tags: #apu #atom #atom-s1260 #datacentre #data-centre #jaguar #microserver #server #soc #system-on-chip
Companies: #amd
AMD has answered the immediate threat of Intel's server-centric Atom processors - and the somewhat more distant threat from ARM's multitudinous licensees - with a new Opteron family: the small-core Opteron X-Series.
Part of AMD's renewed focus on the microserver market - which began with its acquisition of SeaMicro an embarrassingly short period of time before its new subsidiary launched an Intel-based product - the Opteron X-Series is a range of low-power chips designed to pack as many cores into as small a thermal envelope as possible. As with Intel's Atom processors, and the small number of ARM-based microserver processors hitting the market, the emphasis with the X-Series is high levels of concurrency rather than raw performance.
Designed to compete with Intel's sever-centric Atom S1260, AMD's Opteron X2150 - codenamed Kyoto - has a 22W thermal design profile (TDP) and is the company's first accelerated processing unit (APU) system-on-chip design for the datacentre market. As a result, it packs 128 AMD Radeon HD 8000 stream processors alongside its four general-purpose processing cores each of which gets a dedicated floating-point unit and a 512KB chunk of the chip's shared 2MB L2 cache.
Compared to Intel's Atom S1260, the Opteron X2150 certainly has its advantages: as well as on-board GPU cores, which can be harnessed for general-purpose GPU (GPGPU) offload of highly parallel workloads, the chip supports up to 32GB of DDR3-1600 memory per socket - providing you can afford to splash out on 16GB DIMMs - compared to 8GB of DDR3-1333 for Intel's offering and includes four Jaguar-based CPU cores to the Atom's Centerton-based two. It also offers a claimed two-fold improvement in single-thread and overall throughput performance over the Atom S1260, when clocked to an equal 2GHz - although the chip itself will be launching at a maximum clock frequency of 1.9GHz.
As a system-on-chip design, the Opteron X2150 includes integrated support for eight lanes of PCI Express 2.0 connectivity, eight USB 2.0 ports, two USB 3.0 ports, two SATA III ports and DisplayPort, VGA and HDMI video outputs. Built on a ball-grid array (BGA) package, the chip measures 24.5mm by 24.5mm.
The X2150 is also to be joined by the Opteron X1150 CPU-only variant, which ditches the GPU portion of the design for workloads that don't require GPGPU offload. While this doesn't result in any reduction in package size - so as to keep the two chips interchangeable in original equipment manufacturers (OEMs) designs - it does allow for a boost from 1.9GHz to 2GHz and a reduction in TDP from 22W to just 17W. That peak TDP can, however, drop as low as 9W for the X1150 and 11W for the X2150, although AMD has not specified whether such a low power draw is possible under sustained workloads.
While the peak TDP of AMD's Opteron X-Series doesn't come close to touching the 8.5W peak of Intel's S1260, it does include twice as many integer processors - albeit with the same number of floating-point units - as the Atom chip, allowing for double the core density in the same footprint providing adequate cooling is available. The 17W peak TDP of the GPU-less X1150, adjusted for a per-core figure, is also an exact match for the S1260 - meaning AMD isn't as far off the mark as the raw figures might suggest.
The first company to use the new chips will, naturally, be AMD subsidiary SeaMicro, closely followed by HP integrating the processor into its Project Moonshot microserver product, but the company is clearly hoping the chips will have mass appeal in the burgeoning cloud computing market - and, if they perform as well as claimed, it could certainly have come up with something to wipe the smirk off rival Intel's corporate face, especially given the CPU-only X1150's similar pricing of $64 and the extra GPU grunt of the X2150 at $99 (both prices based on buying trays of 1,000 units.)
