Zalman's Reserator 3 is a serious departure from the company's original Reserator, packing a claimed 400W of heat dissipation into a compact sealed-loop cooler.
Zalman appears to be teasing the enthusiast community at present: as well as
an impending fan-free CPU cooler, the company has carefully leaked details of an upcoming sealed-loop watercooler, the Reserator 3.
A significant departure from the company's original Reserator design, which was a large passively-cooled aluminium tube that acted as both reservoir and radiator, the Reserator 3 combines a waterblock and pump with a high-density aluminium-fin circular 120mm radiator. As with other sealed-loop systems, the deisgn is simple: connect the waterblock to the CPU and the fan-equipped radiator to a fan mount and you're ready to go.
According to details picked up by
Sweclockers but not yet made official by Zalman itself, the Reserator 3 will be capable of dissipating up to 400W of heat. That's a significant performance promise, and something that should have overclockers interested in the device.
Further details obtained by the site include an overall weight of 850g, a pulse-width modulation (PWM) duty cycle of 30-100 per cent that can run the fan at between 900 and 2,000 revolutions per minute, and support for Intel Socket LGA 1155, 1156, 1366, and 2011, along with AMD's AM2, AM2+, AM3, AM3+, FM1 and FM2 socket types. Blue LEDs are included in both the fan and the waterblock-cum-pump.
More details are expected when Zalman officially announces the Reserator 3 as part of its presentations at the Consumer Electronics Show in January.
21 Comments
Discuss in the forums ReplyThat's not even possible?
(Not an attack, just interested to see why you think it can't dissipate that kind of heat)
Check the graphs at the bottom of this page for how "proper" 120x3 radiators do with a 10°C delta T and the watts dissipated. The flow rates are probably higher in these examples too, so the 0.4GPM graph is probably most representative. What can be seen is that 120x3 radiators at that flow rate get about 350-400W dissipated at 2000rpm. Assuming that a 120x3 performs 3 times better than a single 120 (which it probably doesn't quite), then Zalman are looking at a pretty large Delta T for 400W...
Hopefully these prove to be more reliable. Their fanless Reserator 2 was excellent (it cooled a Pentium D 945 @ 4ghz + 8800GTX just nicely) and I've only just recently passed it on to a friend.
Any clue as to what coolant will be used? as their blue additive gunked up worse than Porkin's home furnishings. ;)
Edit: shame no 775 socket support :(
It's interesting that they don't use water like regular water cooling systems !
I lol'd
I only wish it came in a red LED variant...
I hate to think what's grown inside
Wasn't the whole point of the reserators that they were external? I gotta admit the originals were a piece of art to have sitting on your desk/floor.
I ran one for a while waaay back maybe 10 years ago. The blocks were pants but the res/rad/pump was pretty pimp.
otherwise THIS IS NOT A RESORATOR, why couldn't they have come up with a new name instead of tarnish a known branding with what will likely end up being a sub-par product :(
thats a combined reservoir and radiator XD
and dont dismiss it before you see final cooling numbers..im sure the same thing was said when they demo'd the first tower coolers, the first all in one water coolers etc etc etc
