Other World Computing's latest SSD features a SandForce controller and a whopping 480GB capacity.
If you were impressed by Mushkin's SandForce-based entry into the SSD marketplace
announced yesterday but wish it was just that little bit more capacious, fret not: Other World Computing is here with a whopping 480GB SSD.
Announced to press by the company yesterday, the OWC Mercury Extreme Pro series of SSDs feature the same controller as used in the Mushkin drives, a SandForce SF-1200 capable of ripping data from the drive at a rate of 285MB/s. Where the drives differ, however, is in maximum capacity.
While the OWC Mercury Extreme Pro series will start at 60GB and work its way through 120GB and 240GB, the range tops out at a quite frankly incredible 480GB - one of the largest SSDs currently on the market.
All the drives include integral 128-bit AES encryption to keep your data safe and secure, along with SandForce's DuraClass technology designed to offer best-in-class endurance and reliability - meaning that your data shouldn't be going missing any time soon.
Before you get too excited, however, there's the little matter of price: currently available exclusively in the US, the top-end 480GB OWC Mercury Extreme Pro is going to set you back $1,579.99 (around £1,070). While that might
seem breath-takingly expensive, it represents an overall cost of $3.29 per gig - not too much of a premium over rival Mushkin's 240GB model at $3.06 per gig.
The company's entire range is available from its
online store now.
Does the idea of a 480GB SSD answer your hopes and dreams for the technology, or does the price per gigabyte need to drop drastically before you'll be tempted away from your spinning platters? Share your thoughts over in the forums.
20 Comments
Discuss in the forums ReplyWhen SSD prices drop by a factor of ten, THEN it'll be worth it.
how much did you just spend on graphics cards pete? :|
Seriously though, I imagine a large capacity high cost SSD will only be used by very specialist applications (and this is where people tell me this is what the company's aiming for) such as computer simulations involving lots of small file transfers.
It'd just be nice to see SSDs come down to a sensible price :( .
well you could argue that 3xGTX480s is a specialist setup for specialist apps (CUDA etc).
and anyway, if you look at the price/storage ratio its similar to 'consumer' drives.
Rainbow Tables.
But i certainly dont have that much cash laying about! :(
Just look at the IBM 3380. In 1980 it offered a whopping 1GB capacity, weighed over 500 pounds, and cost $40,000.
browsing pictures (generating thumbnails) is 5x faster
zip works 50% faster
searching through sources 40x faster
mercurial, git works 3 times faster
various builds 3 times faster
not mentioning overall lightness of the system, where you save seconds here and there
If SSD is going to save you several hours a week, and you are a consultant paid 100 quid for an hour, why not ask your company to buy one for you? It will be paid off in a month.
SSD is the single best thing you could buy you want an fully responsive pc, most users who comment SSDs not worth it are mostly likely never owned one or an good SSD
HDD do bog the system down Vista was extremely bad on some unoptimised hdds i found Hitachi/IBM (or raptors or RAID 0 norm drives) was the best hdds to use for vista as they had very good random access data rates for some reason, but i never use them due to the deathstars, RAID 0 with vista i would recommend on all gameing systems
but windows 7, 1 disk will work quite well as they sorted out the I/O task priority in it
any Crap that windows is doing on the HDD is suspended when user or norm programs are using the disk they also fixed systemrestore/trustedinstaller/shadowcopy from tieing the system up for 10 mins with lots of disk I/O that makes a lot of disk trashing(my orange dongle takes 1-2mins to install on vista some times, on windows 7 less then 20 seconds)
