SODIMM system-on-a-chip launched
The tiny SODIMM-factor TRITON-TX51 requires a baseboard to break out the connectivity, but this can be shrunk via a design service.
If you're always on the lookout for the smallest computing system possible - and the newly-unveiled Mobile-ITX form factor is still a little bulky for your tastes - check out Direct Insight's TRITON-TX51.
As revealed over on Linux for Devices - via SlashGear - the TRITON-TX51 is a an entire computer crammed into a PCB the size of a stick of laptop RAM - just 6.85cm x 2.54cm.
In this SODIMM sized footprint you get an ARM Cortex A8 processor running at 800MHz, 128MB of DDR400 RAM with another 128MB of NAND flash memory, support for a pair of SDIO cards for additional hardware, a touchscreen controller which can output and drive displays of up to 1,280 x 768 at a 24-bit colour depth along with PAL and NTSC video output, a 10/100 Ethernet controller, USB 2.0 On-The-Go and host support, and I2C, SPI, I2S, 1-Wire, and PWM interfaces.
Video support isn't exactly lacking either, with the teeny-tiny system featuring a PowerVR graphics engine which supports both OpenGL ES 2.0 3D rendering and 720p MPEG-4/h.264 hardware accelerated playback - and even manages to cram in support for a CMOS camera device.
Of course, in order to use the functionality of the system a much larger daughterboard is required to hold the outputs in a similar manner to VIA's Mobile-ITX form factor, but Direct Insight promises to offer a baseboard design service that will allow OEMs to shrink the footprint to the smallest possible while still retaining the outputs required for their implementation.
Designed primarily for video processing systems, the TRITON-TX51 is expected to launch in January for €150 with full compatibility for Windows CE 6.0 and Linux kernel 2.6 and above.
Does the thought of such a tiny little system with so much power get your modding juices flowing, or is the lack of x86 compatibility a problem? Share your thoughts over in the forums.
19 Comments
docodine 7th December 2009, 12:57 Quote
"yo dawg, i heard you like ram, so we put ram in your ram, so you can randomly access while you randomly access..."
What can be done with this thing? It's too slow for a media center, can't run windows, etc.
mi1ez 7th December 2009, 13:15 Quote
That is incredible! It may not be the most powerful system out there, but it really is amazing!
@docodine
I don't know what you'd use it for. potentially something like an awesome phone of sorts?
Psytek 7th December 2009, 13:15 Quote
If you read the text on this web page of text... you would have noticed the text which said this was revealed on 'Linux for devices'
The moral of the story is... you really should read text, when you are interacting with a medium which uses text to convey information.
Cupboard 7th December 2009, 13:36 Quote
I can see the attraction in having such a small "computer", however what is the point of having it fit into a SODIMM? They are designed to have memory put in them, not entire computers, so I assume they provide no more than power and a safe place to live? If that is the case, would it not be better to have a proper power connector to un-tie it more a parent board?
Bursar 7th December 2009, 13:40 Quote
It's the size of a SODIMM. It's not designed to fit the SODIMM slot of a laptop. For hybrid set top boxes, it would make a great platform.
widmod 7th December 2009, 13:41 Quote
no forum link?
seems to be a new "feature" since CPC is on board
i would love to see this board in a handset
so i could just swap my handsets cpu for a faster one after a year
i wait to see usb ports on handsets like the latest linux power n900
bigsharn 7th December 2009, 15:22 Quote
I love the idea of this... and E150 (I can't euro sign) for it seems pretty fair
I'm thinking torrent box within an existing computer case :p
B1GBUD 7th December 2009, 15:53 Quote
LOL... Demot please!!
SMIFFYDUDE 7th December 2009, 16:02 Quote
Its still more powerful than my first PC, so it'll play championship manager 00/01 which is what my dad still plays on it.
t1alek 7th December 2009, 19:09 Quote
@Bursar
According to the picture, it does actually seem to SO-DIMM based, for connection between the daughterboard and motherboard.
wiak 7th December 2009, 20:38 Quote
WDTV Touch Micro anyone? :P
frontline 7th December 2009, 22:38 Quote
Originally Posted by t1alek
@Bursar
Yes,
Rkiver 7th December 2009, 23:00 Quote
I want one.
Landy_Ed 8th December 2009, 12:52 Quote
Seems to me like should some enterprising companies also start to manufacture inexpensive compatible parts, especially the baseboard in smaller form, the potential is there for cheap boutique or home-made mobile PDA/phones & any number of other discreet connected devices. Perhaps some of the more enterprising hackers will come up with a way to get the iPhone OS to run on it - same processor after all!
How long before we see a computer running Fedora or CE built into an action man or a 1:43 scale model car ? ...that'd be a neat mutimedia presentation platform actually...
crazyceo 9th December 2009, 08:15 Quote
Yes but it also stated " full compatibility for Windows CE 6.0" Whether it was revealed on Linux for Devices or not, this product is NOT Linux exclusive. Which is a positive as it would be a shame to limit this device to just Linux.
steveo_mcg 9th December 2009, 09:30 Quote
Even worse shame to limit it to windows CE....
Icy EyeG 9th December 2009, 11:37 Quote
I don't know about you guys, but I have the feeling that many of the interesting devices shown at linuxfordevices.com never show up for sale in a large scale... Most of the time you only find them at industrial web stores.
I wonder if this will be the case...
Anyway, the design isn't new:
- http://www.emtrion.de/hicodimm7723_en.php
- http://parts.digikey.com/1/parts/1667198-module-dimm-lpc3250-arm9-somdimm-lpc3250.html
- http://parts.digikey.com/1/parts/1667196-module-dimm-lpc2478-arm7-somdimm-lpc2478.html
Landy_Ed 10th December 2009, 08:37 Quote
Perhaps the key is exposure, on websites like this. For UK buyers, availability is also relevant!
crazyceo 10th December 2009, 09:22 Quote
Doesn't say that either and your point is?
