Chip flaw delays Marvell SATA 6Gb/s launch
Marvell Semiconductor's 88SE9123 SATA 6Gb/s chipset has been delayed due to a flaw with the PATA backwards compatibility.
The first products to use the new SATA 6Gb/s standard have been delayed after chip manufacturer Marvell Semiconductor discovered issues with backwards compatibility.
According to ExtremeTech, the company has been forced to delay its 88SE9123 SATA chipset after discovering issues with backwards compatibility – a delay which has reportedly lead to its removal from planned Lynnfield motherboards from both Asus and Gigabyte.
In a statement, a Marvell spokesperson confirmed that “a hardware issue” was indeed responsible for the delays, but reassured customers that this wasn't down to the recently-ratified SATA 6Gb/s standard: rather, the issue is one of backwards compatibility with old parallel ATA (PATA) devices.
Marvell claims that the issue comes from the “legacy PATA functionality, not the SATA” and that customers looking to implement the 88SE9123 chipset won't be left in the dark too long. Stating that a solution has already been identified, Marvell claims that testing with regards to “compatibility and performance” continues and that a 2009 launch is still on the cards.
The news is unlikely to please the Serial ATA International Organisation, which had high hopes for the new standard, claiming that the finalised spec would lead to additional speed “without compromising the quality and performance [consumers] have come to expect.” While the issues is unrelated to the SATA standard itself, the 88SE9123 was considered a flagship product for SATA 6Gb/s – and any delays are likely to cost the standard.
Should companies be looking to ditch the ageing PATA standard in favour of SATA anyway, or do you applaud Marvell for taking the time to get their chipset right before release? Share your thoughts over in the forums.
30 Comments
_DTM2000_ 17th July 2009, 14:32 Quote
I thinks it's good that Marvell are taking the time to fix the issue but really PATA shouldn't have been part of the design anyway, it's way too old now and the number of people that would want to buy a bleeding edge motherboard and then use ancient drives with it must be tiny. They should have ditched PATA from the start and saved time and R&D costs. We would have had SATA 6Gb/s by now if it wasn't for this.
Goty 17th July 2009, 14:51 Quote
Two words. Optical drives.
DXR_13KE 17th July 2009, 14:58 Quote
3 words:
SATA optical drives.
WhiskeyAlpha 17th July 2009, 15:08 Quote
Originally Posted by DXR_13KE
3 words:
LOL, exactly what I was thinking.
I suppose that there's probably more people using PATA optical drives still than PATA hard disks these days but as suggested previously, who buys a top end mobo with SATA-3 capabilities and then kicks up a stink because they need to shell out £15 for a SATA optical drive?
GFC 17th July 2009, 15:35 Quote
My 2 cents: scre* PATA, who uses that anyway? Go sata go!
robyholmes 17th July 2009, 15:41 Quote
SATA optical drives are like £15! Come on! We don't need PATA
Goty 17th July 2009, 15:50 Quote
Yeah, but why spend the extra cash when I can keep my perfectly capable drive that I've got right now? Plus, those £15 are usually some loud, low-quality pieces of junk.
Boogle 17th July 2009, 16:34 Quote
I've had expensive optical drives, and cheap optical drives. The noise didn't track with cost whatsoever, even the build quality didn't track with cost. I've got a cheap Samsung drive that's been flawless for years while a more expensive NEC drive is no longer able to burn a reliable DVD disc.
It may have been true that an expensive CD-RW or DVD-RW drive was better (due to a larger buffer) but now that under-runs are both less likely to happen and no longer an issue you can get a cheap drive and no longer worry.
Must say though, using SATA drives has improved both the aesthetics and airflow of my case. Must say that ever since SATA optical drives came out I've never wanted a mobo with an IDE or floppy connector - it takes up room and means really rubbish chips end up on the board *cough* jmicron *cough*. Drop PATA/IDE and save a few pennies on the board I say!
billysielu 17th July 2009, 16:44 Quote
I honestly didn't know what PATA was until reading this.
Evildead666 17th July 2009, 16:49 Quote
Yay. I'm all on for dropping PATA completely.
If people need it, then they can get an add-in PCI or PCIe card.....
The floppy and IDE connectors should have gone with the new sockets, AM3 and 1366/1156...
joe-amnesiac 17th July 2009, 17:52 Quote
All well and good, but I'm assuming this is PATA functionality over the SATA connector and cables. Rather than the old IDE connector I think some people are rallying against here.
j_jay4 17th July 2009, 17:54 Quote
+1 for dropping PATA
Having both also lengthens boot up times too.
l3v1ck 17th July 2009, 18:07 Quote
Use uses PATA any more? Maybe the odd person with an old ROM drive. Seeing as they can be picked up for less than £20, I'd say ditch PATA all together on new motherboards, that and the floppy connector. That would also help with motherboard layouts.
l3v1ck 17th July 2009, 18:13 Quote
That should have said Who Uses.
MMerc 17th July 2009, 18:54 Quote
What people don't realize is that a ton of SATA optical drives still use the PATA legacy interface over SATA cables.
If PATA were dropped from the spec, all of a sudden your SATA optical drives you thought was future-proofed would become defunct.
wharrad 17th July 2009, 19:03 Quote
How about just including a PATA -> SATA adaptor in the bundle with the motherboard?
I'm sure they used to around 2002 or so, there's a box full under the spare bed here.
Gooooo on, ditch PATA and use the space for something shiny!
InSanCen 17th July 2009, 21:18 Quote
Somehow, I don't think they heard you.
It's PATA Compatibility mode people, the Physical PATA is usually handled by a seperate chip anyhow's
l3v1ck 17th July 2009, 21:35 Quote
Doh, I thought the chip controlled the SATA and IDE ports. My mistake.
HourBeforeDawn 17th July 2009, 23:47 Quote
there is no need to support pata just like there is no need to support floppy slot or lpt1 serial ports, ugh come on people get with the times lol.
dicobalt 18th July 2009, 07:16 Quote
It's good they decided to fix the problem. If only Nvidia would have bothered to do testing on their chipsets as much to find that weird hdd data corruption problem and fix it *before* launch. I am still unsure if they ever fixed it. >:( Good job Marvell ;)
faugusztin 18th July 2009, 09:49 Quote
This problematic chip is THAT separate chip you are talking about. These boards have 6x SATA/300 connectors, and the extra stuff is usually handled with extra chips, this time with this Marvell - which means 2x SATA/600 connectors and a PATA connector. And no, there is no problem with the ATA commands over SATA, it's just the PATA interface which is problematic.
So yes, ditch the goddamn PATA part, if anyone still wants PATA drives they can get a extra PCI card.
mayhem 19th July 2009, 10:04 Quote
i don't think you lot realise how much of a minority you really are.
"normal" users wont upgrade for 3 to 5 years at least and some even longer. Pata will still be around for a good few more years weather you like it or not.
Look at you MB they still have PS2 links for the keyboard and mouse all though its probably not needed.
InSanCen 19th July 2009, 11:51 Quote
Leave my PS/2 Alone! My mighty Model M Needs it!!! :D
I do appreciate we use new Tech far more readily then 99% of consumers... hell, I have customers that are quite happy using a combo of a G3 Laptop and a Win95 PC.
But I do think that, although I use a lot of Legacy ports (PS/2, PCI, and COM), they do need to die off fairly soon now. I'll just buy a PCI-e card to add any functionality I need... I would rather they used the die real-estate for far more shiny functions and features. I suspect you will see PATA die off in the next round or 2 of chip designs, at least on the high end kit.
I also stand corrected..sort of. hadn't quite twigged that the extra chip's problems were purely on the Physical PATA port. Teach me to read a bit more carefully next time eh?
naokaji 19th July 2009, 15:31 Quote
But those people also don't buy the latest bleeding edge mainboards.
Besides, each mainboard manufacturer releases like 20 different boards based on the same chipset anyway, there is really no need for all of them to have all those ancient connectors, I mean they could ditch them on atleast one of them, which does not mean they can't include them on some other sku.
leexgx 20th July 2009, 06:00 Quote
on high end boards you should not expect PATA any more intel ditch it an year or 2 ago, why Asus and other makers want this option (on Low end motherboard yes i want PATA/IDE as i fix a lot of computers so most still have an IDE DVD-rw saves me having to put an new one in when upgrading there pc)
PS/2 keyboard must be kept as it works even if nothing els does not (no mouse port you can put an 2 port USB in its place like GA do)
USB is not as Plug in play can be more Plug in pray of pop up and asking you to press enter to install the USB host controller or the mouse and keyboard it self {hate new dells that do that they do not even give you 6 ports on the back to compensate your loss of 2 ports}
B3CK 20th July 2009, 08:34 Quote
I work at a pc repair shop; and I would have to vote that loosing pata would only be viable for high end mobo's at either high end oem's or system builders.
98% of customers don't even know the difference between sata/pata, and 90% of those don't care either. Over 3/4 of all our customers use oem systems; ie. dell/hp/acer/etc..
Even though most of the machines I see have sata connectors, usualy 2 or 4 ports, they will still have either a hard drive or optical or both on pata. When they upgrade to a new machine, and don't want to loose their data, or want more than one optical, it saves me a great deal of labor to just pop their old hard drive in as opposed to the time it takes to move the files over to a new/larger drive.
I Would also say I would rather have all my sata ports filled with hard drives, as opposed to loosing some due to using optical drives as well. But I'm a media junky, and try not to delete old programs, even if I don't use them.
l3v1ck 20th July 2009, 09:23 Quote
PATA should go the way of Serial ports, ie available on PCi cards if you need them.
DXR_13KE 20th July 2009, 12:43 Quote
Current motherboards have something like 10 internal sata ports... don't tell me that you cant spare 1 or 2 for optical drives.
faugusztin 20th July 2009, 19:09 Quote
10 is a pretty high number... Typical boards have 6, a bit higher models have 6+2. I seen 10 only at Gigabyte UD5 P55 and AM3 boards.
PS: I don't count eSATA as internal SATA.
DXR_13KE 20th July 2009, 19:49 Quote
And on some asus mobos.
well duh!;)
