The new SATA specification offers double the throughput of existing systems at an impressive 6Gb/s.
If you're looking forward to the next generation of ultra-fast solid state storage but are worried that the clunky old 3Gb/s SATA interface is getting too long in the tooth to keep up, fear not: the finishing touches have been put in place in the SATA Revision 3.0 Specification.
The Serial ATA International Organisation – also known as SATA-IO, and representing a consortium of companies behind the popular interconnection specification – has officially launched a final version of the next-generation SATA specification. In a
press release – via
Engadget – SATA-IO president Knut Grimsrud claimed the finalised spec would allow members to “
design for their customers' products with the speed they crave, without compromising the quality and performance they've come to expect from SATA technology.”
Fully backwards compatible with existing SATA 3.0Gb/s and SATA 1.5Gb/s drives, the new implementation promises throughput of up to 6Gb/s – twice that afforded by the current SATA specification. This additional bandwidth, along with a new streaming command added to the Native Command Queuing technology to allow improved isochronous data transfers for multimedia playback, should keep even the fastest solid-state disk ticking over.
The news is good for laptop users, too, with the power management facilities of the specification getting an overhaul and a newly designed LIF connector to shrink 1.8” drives still further.
A finalised specification does not a commercial product make, of course – and it may well be a while before we start seeing the first drives offering SATA 6Gb/s connectivity on the market; still longer until motherboards sporting SATA 6Gb/s chipsets appear for sensible money. So far no companies have officially announced a launch schedule, although this is likely to change after the group demonstrates what it describes as “
several product implementations of SATA 6Gb/s technology” at Computex Taipei next month.
Are you looking forward to getting your 6Gb/s schwerve on, or does storage technology in general need to improve before we can make use of the extra bandwidth on offer? Share your thoughts over in
the forums.
9 Comments
Discuss in the forums ReplyFrom here:
Especially when you mentioned SATA 3.0Gb/s earlier in the article.
//ninja-edit: Calm down buttercup, SATA 3.0 will be the name for this in public anyways. And now we can at least say Bit-Tech started it. :D
Is that the maximum speed the current level of technology allows or did someone explicitly decide on that number?
I'm curious to know if 6Gb/s really is the max they can do for this new spec. Feels like it shoudl be much higher... :|
http://www.computex.biz/bestchoice/ProductNews_Detail.aspx?index=12
