Gigabyte GA-H55N-USB3 mini-ITX Motherboard Review
June 15, 2010 | 08:21
Tags: #benchmarks #bios #h55 #lga1156 #mini-itx #motherboard #oc #overclocking #pap #pci-express #result #review #sff #small #tiny #usb-3
Companies: #gigabyte
Custom PC Media Benchmarks
Download from: bit-tech.net
We have developed our own suite of benchmarks using real-world and open source applications to simulate how PCs are actually used. The suite comprises an image editing test using Gimp, a video encoding test using Handbrake and a multi-tasking test using 7-Zip to archive and encrypt a large batch of files while a HD movie plays in mplayer.
A score of 1,000 means that the test system is as fast as our reference PC, which used a 2.66GHz Intel Core 2 Duo E6750 at stock speed, 2GB of Corsair 1,066MHz DDR2 memory, a 250GB Samsung SpinPoint P120S hard disk and an Asus P5K Deluxe WiFi-AP motherboard. The scoring is linear, so a system scoring 1,200 points is 20 per cent faster than our reference system. Equally, a system scoring 1,200 is 4 per cent faster than a system scoring 1,150.
For this review, we've used a Core i-750 to get comparative results (the single line) and a Core i5-661 to show the maximum overclocked performance of the board as H55 boards still overclock better with a Clarkdale CPU rather than a Lynnfield.
GIMP Image Editing
Website: GNU Image Manipulation Program (GIMP)
Far from being some kind of pr0n-filtering tool, Gimp is an open source image editing application - Gimp is an acronym of GNU Image Manipulation Program. Our test simulates how well a PC can manipulate a collection of large digital photos, and to achieve a low time requires a PC with a powerful CPU, plenty of quick memory and efficient hard disk drive access.
GIMP Image Editing
Media Benchmarks
  • ECS H55H-I (Core i5-661)
  • Gigabyte GA-H55N-USB3 (Core i5-661)
  • Asus P7H57D-V Evo
  • Zotac H55-ITX WiFi (Core i5-661)
  • Biostar TP55
  • ASRock P55M Pro
  • Gigabyte GA-H55M-UD2H
  • ASRock H55M Pro
  • ECS H55H-I
  • Gigabyte GA-P55M-UD2
  • Asus P7P55-M
    • 1328
    • 1673
    • 1314
    • 1775
    • 1295
    • 1716
    • 1289
    • 1614
    • 1283
    • 0
    • 1275
    • 1605
    • 1274
    • 1664
    • 1263
    • 1706
    • 1178
    • 1409
    • 1171
    • 0
    • 1121
    • 1693
    • 1107
    • 0
    • 1104
    • 1677
1000
1500
2000
Score (points), higher is better
  • Stock
  • Overclocked
Please read the Performance Analysis section.
Handbrake H.264 Encoding
Website: HandBrake
We use the open-source, GPL-licensed, multi-platform, multi-threaded video encoder Handbrake to encode a HD video using the H.264 codec. This primarily tests multi-threaded CPU and memory subsystem performance.
Handbrake H.264 Video Encoding
Media Benchmarks
  • Asus P7H57D-V Evo
  • Biostar TP55
  • ASRock P55M Pro
  • ASRock H55M Pro
  • ECS H55H-I
  • Asus P7P55-M
    • 1967
    • 2669
    • 1966
    • 0
    • 1963
    • 2867
    • 1959
    • 2694
    • 1932
    • 2777
    • 1925
    • 2332
    • 1918
    • 0
    • 1860
    • 2805
    • 1859
    • 0
    • 1818
    • 2897
    • 1811
    • 2266
    • 1810
    • 2304
    • 1731
    • 2209
1000
1500
2000
2500
3000
  • Stock
  • Overclocked
