Crysis
Publisher: Electronic Arts
We tested the game using the 64-bit executable under and DirectX 10 with the 1.21 patch applied. We used a custom time demo recorded on the Harbour map which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game.
For our testing, we set all the settings to High. Because of how intense the game is, we tested with 2x anti-aliasing, but with anisotropic filtering disabled, and at a resolution of 1,680 x 1,050. There is currently no support for anisotropic filtering in the game, but you can still force it from the driver control panel.
Crysis
1680x1050 2xAA 0xAF, All High Settings, Radeon HD 5870
  • Asus P7P55-M
  • Biostar TP55
  • ASRock H55M Pro
  • Zotac H55-ITX WiFi
  • Gigabyte GA-P55M-UD2
  • Gigabyte GA-H55M-UD2H
  • Asus P7H57D-V Evo
  • Zotac H55-ITX WiFi (Core i5-661)
  • ASRock P55M Pro
    • 51
    • 29
    • 51
    • 27
    • 49
    • 26
    • 48
    • 26
    • 50
    • 25
    • 50
    • 25
    • 50
    • 25
    • 45
    • 23
    • 51
    • 22
20
30
40
50
Frames Per Second - higher is better
  • Average
  • Minimum
Crysis (OC)
  • Biostar TP55
  • Asus P7H57D-V Evo
  • ASRock P55M Pro
  • Asus P7P55-M
  • ASRock H55M Pro
    • 59
    • 37
    • 54
    • 34
    • 54
    • 33
    • 60
    • 33
    • 58
    • 33
    • 58
    • 32
    • 50
    • 29
    • 49
    • 26
20
30
40
50
60
  • Average
  • Minimum
For performance analysis, see page 9.
STALKER: Call of Pripyat
Publisher: bitComposer Games
We ran the full STALKER: Call of Pripyat benchmark, with SSAO set to Low, Tessellation enabled, and Contact Hardening Shadows disabled. We run the game in the Ultra graphical options preset, with the 'Enhan. full dyn. lighting (DX11)' rendering. Of the four runs, we only take the results form the last:
1680x1050 DX11 0xAA 0xAF, Extreme Settings, SSAO Default, Tesselation on
  • Asus P7H57D-V Evo
  • ASRock H55M Pro
    • 52
    • 33
    • 50
    • 32
    • 51
    • 31
    • 48
    • 30
    • 50
    • 27
20
30
40
50
  • Average
  • Minimum
STALKER: Call of Pripyat (OC)
  • Asus P7H57D-V Evo
  • ASRock H55M Pro
    • 51
    • 37
    • 50
    • 34
    • 51
    • 34
    • 51
    • 32
20
30
40
50
  • Average
  • Minimum
