Once that's done, we could access the NSD-100 through its web interface. From here on things are pretty self explanatory – you can setup the USB hardware, FTP, sharing and user access, assign it another IP etc.
The first thing we did was to format the hard drive – this option is under the Tools section. Once that's done, we went back to the NetTool facility and setup the Share Mapping – this assigns a particular user to a directory on the drive, so it can be mapped to the drive in the OS.
Emprex NSD-100 P2P Download Engine Using the NSD-100
You can do it from within Windows as well, either way works, but if you're leaving the NSD-100 on 24/7 you'll want it to reconnect the drive at logon; something the Share Mapping function doesn't offer. The USB sockets can be used for external drives – 3.5", 2.5" or flash drives, take your pick, but power consumption and capacity scales accordingly. You can also use USB to connect printers so you have a printer server – it's basically a case of plugging in the printer, refreshing the NSD-100, searching the network and then adding the printer and installing drivers. Simple.
We did manage to power a 2.5" drive in an enclosure direct from the box during testing, but it was only 5,400RPM 80GB single platter disk, not a multi-platter or 7,200RPM drive that will likely require a second USB connector for power. If you use both USB connectors for hard drives, they can't be used to RAID or JBOD the drives – each one remains separate.
Emprex NSD-100 P2P Download Engine Using the NSD-100 Emprex NSD-100 P2P Download Engine Using the NSD-100
Drives can be formatted with either FAT32 or "Linux-HD" which is XFS, but it's worth noting that while FAT32 is more compatible with both Windows and *nix machines, its file size is limited to just 4GB. If you do format a drive under "Linux-HD" it can still be read through the NSD-100 by a Windows machine, it just can't be read directly. While the drives act as storage for the torrent traffic, it'll also act as a NAS and "Media Server" for your network – the drives can be shared and even user partitioned through the NSD-100's web interface.
Shopping
Stats: 0.024 seconds
