Congrats to L3p for finishing this amazing scratch-built mod.
One of the most amazing scratch-built PCs we've ever seen has been completed over the weekend. Tired of heat-related issues and having a large, heavy PC, forum user L3p (also known as Peter Brands from The Netherlands) installed cutting-edge, high-end hardware and a water-cooling system into his desk.
The project, entitled L3p D3sk - Silent Workstation, began in November last year, and Peter also picked up first place in our monthly modding competition
Mod of the Month too.
The desk was custom-built and L3p drilled down into his house's foundations to find a cool home for the system's huge water-cooling radiator. The incredible PC uses an Intel Core i7-980X Extreme Edition that's been overclocked to 4.5GHz, 6GB of Corsair Dominator GT DDR3 RAM, an Asus Rampage III Extreme motherboard and more water-cooling hardware than you can shake a stick at.
L3p will be talking to us in detail about his project soon, so watch this space as there's more to come. As always, pictures say far more than words but we're sure you'll agree with us when we say: 'Wow.'
To see more of L3p's project, head over to his
project log and let us know what you think of the mod in
the forum.
61 Comments
Discuss in the forums ReplyThis is the bit that really blows my mind.
Anyhow love the looks it makes but must be pretty distracting at night but then again when hes using the computer he probably has a switch to turn off the lighting effects.
I was thinking just the same thing this afternoon! I've seen at least 10 world-class projects this year and we're not even half way through the year yet!
Then I see something like this and I just think "BUT ITS SO WORTH IT"
Amazing build, been watching from the begining and its truely exceptional.
I don't envy you at he end of the year trying to sort through them all. At this rate it'll be a total nightmare working out whats going in and what isn't.
Funny, I've spilled it several times on major components and never had an issue and it's a heap load cheaper than fluidxp that I used to use.
Pussy. Real men use Fluorinert. :p
Feser and other similar non-conductive fluids are fine as long as you don't spill it in your PSU. That is the only place where it will cause shorts, due to the high voltages zapping about in there. Only Fluorinert is really 100% non-conductive --and costs a fortune.
As for the desk: it's a desk! It's a PC! It's a desk and a PC! It's freedom in a cup! Er, desk...
Major kudos!
A special about my pc on Bit-Tech ... i only could have dreamed that when i started this !
Bring the lan party to you :D?
LoL
dunx
I may have to enlist some help this year! We always include projects that have been featured in Custom PC and on bit-tech, plus several that never quite made it for various. It's always fun doing it though!
Shame though that in this occasion there aren't nearly enough components to fill the entire desk with. =P
But now first a little break ^^
Semi? fully turgid here
Nar, fraid you're wrong there. A friend lost his PC last month when Feser leaked from CPU block on to GPU. Fried motherboard and GPU. Caused a fire which filled the room with white smoke. I know someone else who had an expensive mobo destroyed by the same coolant. It's 10 x more conductive than the bi-distilled water. But of course anyone who wants to try it out and see is welcome to. Post your results here!
I've never tried Fluid XP.
Using Thermochill EC6.
but this mod is seriously beautiful. I love how he managed to stick the hard drives so far away and still not show any cables at all.
Lets not get silly here, any leak on live electronics is NOT good and all precautions should be taken to avoid it. A properly set up loop shouldn't leak at all, especially if its thoroughly checked.
G69T has some difficult competition lol
I'm with kaiser on this.
Even the best, least-conductive coolants will absorb metallic particles from the block surfaces and radiators they come into contact with, making them conductive over time.
You're probably okay if spilling non-conductive coolant by Feser and the likes on your gear straight out of the bottle or if you get a leak/burst within a few months of building the loop; but over time that coolant will become as dangerous to electronics as tap water.
Just host the party then!
The cables are even 200cm. That was one of the things i thought it would give troubles.
But after 4 months running with 100cm sata+100cm sata extension i still didn't have any problem at all.
There is one thing that can give problems, that are all the 12V cables with extensions.
The voltage wil lower cause of the lengths.
Thats why im using a 700W and a 800W psu now, no problems at all :P
Agree. And since it is clear even by looking at the labels on feser one versus feser bi-distilled that the feser UV is 10 x more conductive then at least by choosing the least conductive you are protecting your hardware for longer. My Thermochill EC6 is more than 12 months old but still non-conducting (it leaked on to my upper 560Ti from cpu waterblock nozzle which had been improperly secured. The GPU was running happily even with a blob of sticky honey-like liquid that had dripped on to one of the power transistors.
Do you have a high-res copy of this picture:
http://images.bit-tech.net/news_images/2011/05/amazing-water-cooled-pc-in-a-desk/2-1280x1024.jpg
Would make an amazing desktop wallpaper!
http://tweakers.net/gallery/45974/fotoalbum/?MapID=16028
He hasn't modified anything, he's scratch built it.
I like the idea, and it looks incredible, but I wonder how much it costs. I imagine that just the radiator could be installed in a much simpler desk and sold for much less. This to will come after the initial marketing phase
Is it not a computer case that's been 'modified into a desk?
Not if it's been scratch built it's not!
I'm completely turned off from mod comps with internet votes now but I'm not turned off modding :D;).
I think he means " TIMMMIIIIIIEEE"
Beautiful mod... I'd just hate to have my ashtray sitting on it, as I am a master of burning holes in my own desk!
