Underneath the cam shell, there's still a Shuttle XPC.
German site
PlexMod.de, is displaying a pair of absolutely fantastic modded Shuttle XPCs. It not only do they look great, they also appear to be engineered with practicality in mind too.
The whole top lifts forward to reveal the XPC chassis underneath. Along with the custom case, the optical drive is now found underneath and internally, everything that could be has been coated black.
There is also the obligatory custom lighting, but is wonderfully executed and subtle to suit the design. Finally, not only is he good with metal and paint, but the modder also made custom fabric cases to keep them in too!
Included is a full work log to tell you how they were made, in case you want to have a pop at something similar or just want to understand what went into such a mammoth project.
Don't stress that you don't need to speak German, because the pictures do all the talking.
You can also head over to our own
Project Logs forum which contains hundreds of similar work logs for various modding projects the talented bit community has undertaken. For this one though, you'll have to pop
into the news forum to discuss it.
17 Comments
Discuss in the forums ReplyMy only complaint with this system is that all the cables come out above the DVD drive - I would have preferred the drive to be above those (in the lid).
thanks for your nice comments and i must admit that it makes me proud
that my casemod is on the bit-tech news. Thanks ;)
Please excuse my english is not so perfect, that's the reason why i only put my
worklogs on german modding forums... it's hard to explaim something if you dont
know the correct words for it ;)
@Tyinsar this was the best place for the dvd-drive, because now you got a better look
on the wd raptorX ;) (and the raptorx is directly in front of the rear fan).
@dream caster no there is nothing to close the case at the moment.
I made two little holes on the back of the upper part and right there i will
do something from aluminium to lock the case with two thumb-screws - but at the moment
it's just an entry on my to-do-list ;)
This is what I was suggesting:
current setup (side view) _______________ | \ | \ | \ | \ |__________ \ | D V D | / |__________________/ My Suggestion _______________ | D V D | \ |---------- \ | \ | \ | \ | / |__________________/ /\ top open /\ \ / \ D \ / \ V \ \ \ D \ ___________\ \ / \ | cut out / \ \ |--------- \ \ | \ / | \ / | \ / | \ / |__________________\___/Please understand that I do not want to take anything away from the wonderful case you have crafted. I really like the way your case looks now. I especially like the DVD at the "back" (which would now become the front for me) and all the work you have done on this is Very professional.
What I am suggesting is just the way I would prefer it if it was made for me - I think this suggestion would still allow you to show off the raptorX and all the internal details and it might make your next case even better.
But when the dvd-drive is in the top, then i think i got some Problems with
the stability of this construction - or i have to use a slimline dvd ;)
and when the top is closed and the Led-lights inside the top are on,
then you will not see very much of the raptorx.
So in my opinion is this construction with the dvd on the bottom
the best solution ;)
I remember seeing one earlier Shuttle mod by you and you are one of many inspirations on my ongoing Shuttle mod :)
Mad creds man :D !!
Hey Bit-tech readers, don't forget to check the others creations of Benny, this guy is a modding god!
I remember one of your shuttle mods from before the purple/red and aluminium one that was good, but this is even better :)
Would be nice to see an English work log for your next project here in bit tech. Any chance of that ? :)
