Robots in disguise... as case mods.
Like most
bit-tech readers, we enjoy having a good surf around the
Project Logs forum and seeing what's going on. There's always a plethora of mod projects in there to while away a boring morning.
So, firing up the forum this morning, I came across this little gem, by forumite
TheMightySpud. Called
Project 'Til All Are One, it is a Shuttle mod with a Transformers theme. The Shuttle has been modded to house a TFT display in the front, and a slot loading DVD.
The casing has been awesomely painted with a Transformers theme, using a cunning set of stencils and artwork (as well as some wicked airbrushing skills).
Being a child of the 80s, I'm a huge fan of Transformers, and I'm sure lots of you will be, too. Optimus Prime? The Decepticons? If you're a fan of the series, you should definitely have a read of
5 things you didn't know about the upcoming movie.
Check out the mod
here then post your feedback in the Project Logs Discussion thread,
here.
