7" touch-screen case gets reviewed
Nice, huh?
HTPC News has the inside scoop on an awesome new home theatre case from Uneed (yes, I do need actually!)
The X15e is an aluminium chassis with an integrated DVD faceplate, a gorgeous lighty-uppy powerbutton and, best of all - a 7" integrated touch screen!
The screen runs 640x480, and looks pretty gorgeous from the pictures. The chaps at HTPC cunningly set it up to run some Konfabulator widgets, giving a handy always-on clock (a major deficiency in Windows Media Center) as well as weather data.
The case itself appears to be well designed on the inside - although, as will all HTPC cases, things seems to get a little cramped once the kit starts going in.
The boys thought that "The touch screen control was a pleasure to play with and really gave the case that "woah" factor. Navigating in MCE was a little hard when it came to the smaller stuff so luckily a small stylus was included to ease the process."
You should definitely check out the whole review, which is here.
Discuss this article!
