NZXT Releases Noctis 450 Mid Tower case
Written by Antony Leather
April 28, 2015 | 17:54
Tags: #nzxt-noctis-450-review #water-cooling
Companies: #nzxt #nzxt-phantom-case-review
NZXT has announced the latest case in its line-up - the Noctis 450
The case is a mid-tower design with similar aesthetics to the company's Phantom range of cases, but with a few key differences.
The case's showpiece is are 'floating' ventilation panels on the front and roof sections, which combined with mesh backing, NZXT claims it offers 10 times more ventilation surface area than the H440.
As with other cases in its current line-up, including the H440, the Noctis 450 sports underglow lighting as well as rear I/O panel illumination. There's also an updated lighting switch that allows multi-step lighting configurations.
The case offers an 8-channel PWM fan hub, which can be connected to a PWM header on a motherboard to take advantage of any automatic system fan control. The hub can also be connected to NZXT's range of Kraken all-in-one liquid coolers, while you can adjust the fan curve profiles using it free CAM software.
The case comes with three FN V2 120mm fans and an FN V2 140mm fan out of the box, while the front and top fan mounts also offer space for radiators up to 360mm in size.
NZXT Releases Noctis 450 Mid Tower case NZXT Releases Noctis 450 Mid Tower case
NZXT states that the Noctis will be available to pre-order immediately at a price of £99.99/€139.99.
Let us know your thoughts in the comments.
