BitFenix Launces Neos Budget ATX Case
Written by Antony Leather
May 15, 2014 | 10:05
Tags: #atx-case #best-cheap-pc-case #best-pc-case #bitfenix-neos-review #budget-case
Companies: #bit-fenix #bitfenix
BitFenix has launched the Neos - a £30 chassis aimed at value-conscious gamers.
The Neos is available in a variety of colour combinations allowing you to customise the external look of the chassis with a multitude of different vent and grill covers. Despite costing just £30, it offers features such as tool-free mechanisms, dust filters and support for extended length graphics cards (30cm).
The interior of the BitFenix Neos allows for a maximum capacity of three 3.5in hard disks, three 2.5in SSDs and two 5.25in bays for optical drives. The Neos can accommodate CPU cooler heatsinks up to 160mm in height (155mm for windowed version) and will support full-height 120mm single-fan water cooling radiators.
The case stands 429mm tall, 185mm wide and 470mm deep, is made of steel and plastic with a dash of BitFenix's SoftTouch material and also offers USB 3 ports on the front panel. There's a single 120mm fan included as standard, mounted in the rear, with space for a further two 120mm fans in the front of the chassis.
The Neos benefits from removable front and bottom dust filters, tool-free drive and motherboard installation and an aluminum logo badge. the front grill mesh is interchangeable to add a splash of personal style onto the chassis. The Neos will be available in both black & white and solid or windowed versions.
You can read more and check out the range over at Overclockers.
BitFenix Launces Neos Budget ATX Case BitFenix Launces Neos Budget ATX Case
