Bitspower releases MSI Z77IA-E53 full cover waterblock
The MIZ77ITXA's large cooling plate cools the CPU, VRMs and chipset with a single inlet and outlet port.
Bitspower has released it's latest mini-ITX full cover waterblock, the MIZ77ITXA, which is compatible with the MSI Z77IA-E53 motherboard.
The waterblock features a single G1/4in thread inlet and outlet and a large contact plate that appears to cool not just the CPU but the VRMs and chipset too.
Our review of the company's first such waterblock, for Asus' P8Z77-I Deluxe mini-ITX motherboard, showed that it was fairly easy to install but doesn't quite cool as well as a dedicated CPU waterblock.
However, given the tight confines of many mini-ITX cases, the extra cooling for the chipset and VRMs could be very beneficial.
The release of the MIZ77ITXA is the first non-Asus mini-ITX motherboard waterblock the company has released, so there are now hopes that the latest Z87 motherboards from MSI, Gigabyte and ASRock might get the water-cooling treatment too.
Bitspower releases MSI Z77IA-E53 full cover waterblock *Bitspower releases MSI Z77IA-E53 full cover waterblock Bitspower releases MSI Z77IA-E53 full cover waterblock *Bitspower releases MSI Z77IA-E53 full cover waterblock
Features :
  • Design For MSI Z77IA-E53 (Intel Z77).
  • Unibody Style Construction Design. (U.S.C.)
  • North + South CHIPSET ONE Piece Design With MOS Block.
  • Cover Almost All Heat Area.
  • Real Full Water-Cooled Solution.
  • Block TOP Cover Made Of Hi-Quality Acrylic.
  • Block Base Made Of Hi-Quality Copper.
  • Block Base High Durability Nickel Finished In Silver.
  • RoHS Compliant.
  • ( LxWxH ) : 105.5x133.85x19.9 (Out-Line).
  • Thread : G1/4" x 2
Included :
  • Arctic Matrix 2.5G X 1PCS.
  • Thermal PAD Included.
  • Backup O-Ring For MIZ77ITXA x 1Set.
  • Mounting Screws/Accessories - EZ-STAND OFF Mounting Ready.
Will you be buying the MIZ77ITXA? Which mini-ITX motherboard do you want to see a waterblock for? Let us know in the forum.
4 Comments
Nexxo 7th November 2013, 18:21 Quote
That's all very pretty, but when do they hit the shops?!?
GuilleAcoustic 7th November 2013, 18:38 Quote
I want one for the FM2 / FM2+ itx mobos .... om nom nom
Combatus 7th November 2013, 19:40 Quote
Just waiting for prices/shops and I'll drop it them here
Nexxo 7th November 2013, 21:50 Quote
Good. I want one for the Asus Impact mobo.
