Corsair announces Hydro Series H75 dual-fan cooler
Corsair's new H75 is the H60's bigger brother, shaving the radiator thickness to make room for a pair of high static pressure fans.
Corsair has announced its latest sealed-loop liquid cooler, the Hydro Series H75, which boasts a compact 120mm radiator packing two fans and claimed boosted cooling performance.
Designed as an upgrade from its existing H60, which has a 120mm radiator designed for use with a single fan, the H75 has been redesigned for dual-fan layouts. The radiator itself measures 120mm by 152mm with a svelte 25mm width, and comes pre-loaded with a pair of SP120L PWM-controlled fans boasting a 54 CFM airflow at 2,000 RPM with a 31.4dBA noise level.
The radiator is connected to a low-profile cooling block through kink-resistant rubber tubing, as usual. Inside the block is a ceramic bearing pump and a copper micro-fin cold-plate. A tool-free mounting bracket, officially listed as being suitable for Intel LGA 1156, 1155, 1150, 1366 and 2011 or AMD AM2, AM3, FM1 and FM2 sockets, connects the block to the CPU.
Xavier Lauwaert, director of product marketing at the company, has indicated that the H75 is to be sold alongside the existing H60 as an alternative for those who need additional cooling performance but who don't have room in their cases to cram a second fan onto an H60 or upgrade to a larger radiator.
As is typical for the Hydro Series family, the sealed-loop system - totally maintenance-free, Corsair claims, beyond cleaning out the fans every once in a while - comes with a five-year warranty. The cooler is due to launch in November, with UK pricing yet to be confirmed and a US manufacturer's recommended retail price of $84.99 (around £52, excluding taxes.)
11 Comments
Hamfunk 25th October 2013, 11:23 Quote
So it's an H80 then???
Gareth Halfacree 25th October 2013, 12:01 Quote
No. The H80 has a 38mm-thick radiator which, when the two fans are added, makes it unsuitable for more compact cases; the H75 has a 25mm-thick radiator.
Hamfunk 25th October 2013, 13:11 Quote
Ahhhh, that makes more sense. Thanks.
Panos 25th October 2013, 13:42 Quote
H60 wasnt that good, even compared to H50. And I doubt anyone is around that used only 1 fan with those systems.
Even the H100 asks for push-pull config, and while is huge, there is space around to put it on on most cases today. (top). And yes I have one (as did a H50) and I know how big it is.
SchizoFrog 25th October 2013, 14:11 Quote
The H75 is an H60 with 2 fans instead of one. The price on Scan is about £9 more expensive (£67.98 as opposed to £58.32) so the price seems about right for a matching and included extra fan.
The thing that bugs me is the name. Using 75 instead of 65 implies to me that it is a better unit than the H60 and yet it is virtually the same except for the fan.
Gareth Halfacree 25th October 2013, 14:19 Quote
Actually, it isn't: as it says in the article, the radiator is redesigned and slightly thinner. The H60's radiator is 120x152x27mm, the H75's radiator is 120x152x25mm.
SchizoFrog 25th October 2013, 16:33 Quote
I need more details to totally agree there. The article says it was redesigned for dual-fan layouts (not sure layout is the correct term to be used there), it doesn't say that the rad itself was redesigned as in the design of the internal fluid chamber. This leads me to believe that the change in thickness is a change to the outer shell of the rad rather than an overall change of design.
The proof will be in the testing. Many users have added second fans to a H60 so it will be interesting to see what the figures are between an H60 with 2 fans and an H75 as stock. However, I doubt this test will be done here on Bit-Tech as the argument of 'choice of fan and various cost differences' is often used for not doing certain comparisons, such as adding extra fans to cases for example.
Gareth Halfacree 25th October 2013, 16:42 Quote
You've got as much information as me, there: the radiator is thinner, that's as much as I know.
Pookie 25th October 2013, 18:24 Quote
However you dress it up, it's hardly worth getting excited over.
Chicken76 27th October 2013, 19:42 Quote
Who will be manufacturing these? CoolIT or Asetek?
Baz 29th October 2013, 16:06 Quote
It's an asetek model with a re-designed mounting and Corsair Sp-120 fans.
