Nvidia announces FLEX: Unified GPU PhysX
Nvidia FLEX showing water flowing over cloth surfaces.
Nvidia has announced FLEX, a new unified approach to its PhysX physics simulation SDK, along with two new simulation technologies: FlameWorks and GIWorks.
FLEX aims to unify the various physics simulation technologies previously demonstrated by the company into one SDK. These include things like fluid simulation, solid body interaction, soft body interaction, cloth simulation and more.
The result is a single integrated SDK that 'just works', allowing for easy creation of complex physical interactions such as solid objects floating in water and crashing into each other, or water pouring across a cloth. Perhaps the best example, though, is a water balloon. The single SDK can be used to create a bouncing ball of water that can be popped and pierced - producing a spurt of water.
Tony Tamasi, Nvidia SVP for Content and Technology, described how the new technology was particularly exciting because it allowed for the creation of realistic fluid filled bodies that explode or spurt blood when you shoot them - gruesome but impressive.
Also announced today at the company's The Way It's Meant To Be Played press event in Montreal was GIWorks, a new global lightning SDK that aims to make true global illumination available in real time. Normally global illumination - the use of dyanmic lighting rather than pre rendered lighting effects - is too computationally intensive to use for all aspects of games but Nvidia thinks it has cracked it with GIWorks.
Finishing off today's trio of announcements is Flameworks, a new real time volumetric flame simulation technology that the company claims provides cinema quality flame simulation but that will run on current graphics hardware.
Nvidia showed demos of all three technologies running on a single GTX Titan, and the effects were all very impressive. It remains to be seen how well, and how quickly, they can be integrated into upcoming games, though.
One final tidbit that Nvidia revealed was a demo of FaceWorks, the company's sophisticated facial animation technology running on Project Logan, the upcoming replacement for Tegra 4. Project Logan, which is likely to come to market as Tegra 5, is the first of Nvidia's mobile SoC to use a Kepler based GPU. Nvidia claims it can run Faceworks yet the chip is still a sub 10W part.
Nvidia Project Logan running Faceworks
6 Comments
rocknroll237 17th October 2013, 22:22 Quote
"Finishing off today's trio of announcements it Flameworks"
'it' should be 'is'
"and the effecst" on the second to last line.
I thought you guys would have spell check! :P
Teelzebub 17th October 2013, 22:27 Quote
'it' should be 'is'
Never heard of the edit button?
joplin66 18th October 2013, 01:04 Quote
pretty interesting timing after AMD's new API anouncement.
Panos 18th October 2013, 11:26 Quote
Nvidia has GPU Physx since 2007 and only 40 games support it out of a gazillion (hell not even Crysis support it).
(+12 games that support the Ageia PPU only between 2005-7).
Seriously, still advertising a 8 year old proprietary tech that hasn't lifted out of the ground yet seems how pathetic and desperate have become.
erratum1 18th October 2013, 14:16 Quote
The tech is interesting but it takes a while for it to appear in any good games.
