BitFenix announces a raft of new small form factor cases, with the Colossus M, Phemom M and Prodigy M, as well as two as-yet un-named cases on display at Computex 2013.
BitFenix already has a strong position in the Mini-ITX market, with its acclaimed
Mini-ITX Prodigy chassis continuing to win favour thanks to its great capabilities and low-price. There’s clearly been no laurel resting at BitFenix though, as it chose to launch three new small-form-factor cases, and preview a pair of as-yet un-named models at Computex 2013.
First up is a new variant on the existing Prodigy chassis, Prodigy M. The M changes the interior into an inverted M-ATX layout, placing the PSU mount in the floor of the case and moving a 3.5in and 2.5in drive bay behind the motherboard, all without changing the Prodigy’s already compact exterior dimensions. The divisive wobbly case feet do remain, but the addition of a 240mm fan in the base and mounts for 2 x 120mm fans in the roof and front of the case mean that the Prodigy M will be just as, if not more, capable as its fore-bear when it comes to cooling.
  The Prodigy M offers an inverted M-ATX design, but retains the same Prodigy dimensions
Also on display was the Colossus M – the mini-ITX successor to BitFenix’s very first case, the Colossus. Built on the same chassis as the Prodigy and with the same interior layout as the Prodigy M, the Colossus M adds a drive-bay-free front fascia and wrap-around LED lighting that can be switched between red, blue and green. The Phenom M, with more discreet looks courtesy of its soft-touch plastic fascia and curved lines, uses the same interior too.
  The sleek Phemom M and this mini-ITX prototype are both based on the original Prodigy chassis
Finally, BitFenix also showed off a pair of early prototype cases. The first, using a slanted M-ATX design, makes heavy use of BitFenix’s favoured soft-touch matt finish and its smooth lines means it’s a real looker, but inside the layout is rather fairly standard stuff. The other prototype is a Mini-ITX twist on the Prodigy, replacing the plastic handles and feet with a more smooth and stylish (not to mention stable) alternative.
  We love the look of this M-ATX prototype, with its angled M-ATX layout and soft-touch finish
