NZXT Launches new Phantom 530 and H230 cases at Computex 2013
The Phantom 530 will also be available in white and black
NZXT has unveiled a pair of new PC cases here at Computex 2013: the Phantom 530 and new low-noise chassis called H230.
It’s been a frantic week for new product launches at Computex 2013 and NZXT hasn’t missed out, launching a pair of new cases; the Phantom 530 and the H230.
The Phantom 530 continues the now familiar Phantom styling, but adds a larger door and reduces the area of trim around its front and roof fascia. The ATX case can support up to a triple-120mm radiator in the roof, with a double-120mm-radiator in the front, while still offering all the NZXT extras such a built-in fan controller and rear I/O lighting.
Plenty of cable routing options behind the painted motherboard tray, removable drive cages and removable fascia plates make customising the interior to suit your hardware and cooling needs easy, while the overall build quality was impressive; we’ll be getting our hands on a review sample soon.
Contrastingly, the H230 is a low-noise chassis that eschews the bold styling of the Phantom for a more minimalist approach. With noise-deadening padding on the side panels and inside of the front fascia’s door there’s understandably fewer fan mounts, although the middle drive cage can sill be removed to optimise airflow.
NZXT Launches new Phantom 530 and H230 cases at Computex 2013 NZXT Launches Phantom 530 and H230 cases at Computex 2013 NZXT Launches new Phantom 530 and H230 cases at Computex 2013 NZXT Launches Phantom 530 and H230 cases at Computex 2013
The Phantom 530 retains the fan controller an rear I/O lighting
The H-230 is large and spacious, with noise-deadening foam on its side panels.
Like the look of the new Phantom and H230? Or will you be looking elsewhere for your next chassis. Let us know in the forums.
4 Comments
damien c 6th June 2013, 10:12 Quote
My next case is going to be a 900D, Little Devil LD-V8 or a self build.
I have a Switch 810 at the moment and it's not bad, but it just feels cheap and the clips for the top fan cover have broken after it was took off a few times during rebuilds.
Won't be buying another NZXT case.
Eiffie 6th June 2013, 21:29 Quote
Don't hate on Billy Zane and his movies, the guy is great! Have you even seen Demon Knight?!
ssj12 7th June 2013, 05:41 Quote
I have always bought NZXT cases. I have always loved them. Amazing airflow when you have all fans installed. I have no idea why you people say the feel cheap. The plastics are always pretty strong. I haven;t broken a tab or anything yet and I have rebuilt and done full cleanings of all my cases numerous times throughout their usage. I find full aluminum cases look like crap and never have style.
Elton 7th June 2013, 07:14 Quote
I think I might grab an the 530. It's not that bad looking and the window is rather nice.
Plus it'll be a bit cozier than my gigantic HAF.
