Swiftech's latest watercooling kits, the H20-x20 Elite Series, is designed to offer an expandable alternative to sealed-loop systems.
Swiftech has taken the wraps off its latest products for watercooling enthusiasts, the H20-x20 Elite Series cooling kits.
Designed to pick up where the H20-x20 Edge Series left over, the H20-X20 Elite series packs the company's Apogee Drive II CPU waterblock with its integrated pulse width modulation (PWM) controlled MCP35X pump with a MCRx20-QP Res Revision 2 radiator with integrated reservoir. The kit uses Lok-Seal 1/2" and 3/4" compression fittings, comes complete with Helix 120mm PWM-controlled fans and the company's new eight-way PWM splitter allowing centralised speed management of all PWM-compatible pumps and fans in a system.
Those opting to buy the H20-220 Elite will find themselves with a dual-120mm MCR220-QP Res radiator, while the H20-320 Elite packs a triple-120mm MCR320-QP Res radiator. Both include the Apogee Drive II waterblock with integral pump and support for Socket 775, 1155, 1156, 1366 and 2011, along with Tim Mate 2 thermal compound. What isn't included, however, is any way of connecting the waterblock to an AMD CPU socket, with Swiftech stating that it will provide a hold-down plate and mounting hardware for Socket 754, 949, 940, AM2, AM3, 770, F, FM1 and FM2 for free upon request.
Inside the box, buyers will also receive a 500ml bottle of pre-mixed HydrX coolant, six feet of 3/4" OD and 1/2" clear tubing, a filling funnel, and an installation guide.
The kits are being positioned by Swiftech as an alternative to sealed-loop watercooling systems, offering expandability and ease of customisation not offered by all-in-one units. The system is also claimed to be extremely reliable, covered by a 10 year warranty and with a pump rated for 50,000 hours of use, while the coolant should need topping up only once every couple of years. The H20-x20 family is also expandable, with Swiftech claiming the integrated MCP35X pump has enough head pressure to support the addition of a graphics card into the loop without having to add an additional pump.
UK pricing for the Swiftech H20-X20 Elite family has yet to be confirmed, with US pricing set at $239.95 to $279.95 (around £151 and £176 respectively, excluding taxes.)
11 Comments
Discuss in the forums ReplyIs it just me?
Dont worry Tony its not just you, those Cod adds are a pain and your not the first to mention it either.
I guess only testing will tell.
Sent from my Nexus 7 using Tapatalk 2
I am a fan of the closed loop systems, but I do wish that they would supply them with Scythe GT's (or no fans at all). Once these fans are installed, the performace is far better than with the standard fans.
If you want simple.... go the corsair or other closed loop route.
If you want flexibility.... go the full watercooling route with parts from market wide suppliers.
Paying such a premium for sonething that is kinda in the middle just doesnt make sense.
also users that are new to watercooling will enjoy this as they wont have to worry about tube sizes, compression fittings and all that as everything is included ( and you dont have to opt for the dual unit, you can opt for the triple rad set instead )
Well I guess you'll have to wait for reviews, but our own tests show this kit about 8C better at equal fan speed in a highly o/c'd system. All it means is that you could run our kit at the lowest fan & pump speed (800 rpm = inaudible) and still beat the H100 running at its lowest (1300 = quiet) by about 2C. But the fact of the matter is, if you do not overclock, or if noise and CPU temps don't bother you, then you do not need a high-end kit, and the H100 will suit your needs just fine, actually a high-end air cooler like the DH14 would also do just fine.
The point of these kits is not so much the performance difference, because when push comes to shove, the performance criteria/needs vary from one user to another, the point is upgradeability: the ability to add devices to your loop and this is at the very core of the enthusiast PC builder community.
Now, to those who prefer to tailor their own kit from various parts gathered here and there either on the basis of looks, performance, price, or what have you, I must admit that a complete kit cannot compete with the fun factor deriving from choosing their own parts.
A complete kit such as this one bundles the very best parts a company like ours has to offer, and aims at the people who do NOT want to guess whether their parts will work well together or not. It has a specific set of features that include top performance, ease of installation, upgradeability, and more, all based on 15 years of experience in manufacturing liquid cooling parts.
