The new Apogee Drive II features a heavily modified version of the highly popular Laing DDC 18W pump.
Swiftech has announced the Apogee Drive II - the successor to its popular Apogee Drive combined pump and waterblock.
The Apogee Drive II combines a powerful 18W MCP35X pump with a waterblock very similar-looking to it's Apogee HD standalone waterblock. Performance, according to Swiftech, is actually better than using its Apogee HD waterblock and separate pump on LGA1155 and LGA2011.
The Apogee Drive II has the usual G1/4in threads, with the inlet and outlet located on external, tilted side sections either side of the main waterblock and pump assembly. There's apparently enough room for all popular makes of compression fitting to.
Three versions will be available - one for all major Intel CPU sockets from LGA775 to LGA2011, another focusing on LGA2011 alone and the third for all major AMD sockets from Socket 754 all the way up to Socket AM3 and FM1. The kit also comes with an illuminated logo, along with red, blue and green light plates.
Power is provided by a 4-pin molex connector with a 3-pin fan connector dealing with PWM and providing power to the LED in the illuminated logo.
In addition to the Apogee Drive II, Swiftech also announced new radiator and fan models. The MCRx40-QP radiator is built for use with 140mm fans and has 12 fins per inch meaning it should be well-suited to low rpm fans. All models in the series appear to be half-height or 30mm deep and use a two-pass, single row configuration with all-brass construction.
A new fan is in the works too - the Helix 120, which sports a Z-Axis bearing, although is it just us or does this look suspiciously like a Scythe Gentle Typhoon?
Are you interested in the Apogee Drive II? Let us know in the comments.
16 Comments
Discuss in the forums ReplyI'll be putting it in Nano Tower.
Any news on prices?
AMD should be out in week or two.
You can also get version without pump for $69.95.
Wowza, that pump better be good, because a MCP350 + EK HF block of your choice will cost the same.
Antony: I know I'm always requesting stuff, but a pump roundup would be spectacular.
Either way; I'm sure we'll be able to hack it to the 18W version if we happen to need moar power.
Wait, no. I'm wrong. It's the full fat 18W version out of the box.
... Surely the average motherboard would cook the fan-header if you tried running that off that alone. Some of the ROG boards that claim they can run 4Amps for the fans might just manage it, though.Herpa de derp derp. I'm really not reading stuff today. The molex design is nice, while the PWM actually drawing power from the board is a good idea, as it'll likely prevent some motherboards from going "Wtf? Why do I have RPM but no power drain?", if there's even a test for that, that is.
So you got free delivery!:)
Think you missed an O there.
I like the heatsink on the pump. I can see me modding that to include a small fan
"one for all major Intel CPU sockets from LGA775 to LGA2011,"
Guess that's my baby then. Who's stocking them?
Are you sure you're not on the wrong site? :)
