The leaked spy shot allegedly represents the first look at Intel's upcoming Haswell processor family, due to launch in 2013.
Intel's next-generation processor architecture, Haswell, has been pictured for the first time in a spy shot of an engineering sample.
According to Slovakian technology site
OBR-Hardware, the leaked image is of a quality control sample produced at an Intel fabrication facility to prove the next-generation architecture's efficacy ahead of its launch next year.
Built on a 22nm process, Haswell represents the 'tick' portion of Intel's 'tick-tock' development cycle: where the upcoming Ivy Bridge is merely a process size shrink from Sandy Bridge's 32nm to 22nm, Haswell represents a new generation of microarchitecture.
Based on the the existing Core architecture, Haswell promises numerous improvements over its predecessors. The most interesting of these, and sadly invisible in the leaked picture, is HNI: Haswell New Instructions.
Designed to extend the existing instruction set available in Ivy Bridge, HNI includes Advanced Vector Extensions (AVX) 2 with support for SIMD (Single Instruction, Multiple Data) operations on 256-bit integer data types, bit manipulation instructions for improved handling of variable bitstreams, cryptography, compression and large number arithmetic, gather instructions for vectorising codes with non-adjacent data elements, any-to-any permutes with support for DWORD and QWORD granularity permutes across an entire 256-bit register, vector-vector shifts and floating-point multiply accumulate functionality for boosted floating point performance.
In simpler terms: for software designed to take advantage of the new instructions, Haswell promises some significant performance benefits. In particular, better vector handling means vastly improved parallel processing capabilities that could boost overall compute performance significantly for multi-threaded applications.
The image does, however, offer some insight into other aspects of the first Haswell-based processors likely to hit the market: according to OBR-Hardware's analysis of the spy shot, the GPU portion of the die is around twice the size of that included in Sandy Bridge. As a result, we can expect significantly improved graphics performance from the chips.
That observation fits with existing claims - including that from
VR-Zone - that Haswell will include multi-standard encode and decode functionality for video resolutions up to QuadHD 4K.
Sadly, with Ivy Bridge not even out of the door yet, Intel is keeping quiet on precise facts and figures for the first Haswell silicon; but it certainly looks like it's going to be a tempting upgrade for performance enthusiasts when it finally hits the market in 2013.
Will you be skipping Ivy Bridge in the hope that Haswell is all that it promises to be, or do you take Intel's proclamations as to the benefits of HNI with a pinch of salt? Share your thoughts over in the
forums.
18 Comments
Discuss in the forums ReplyMmhmm.......yeah........mmhmm........I know some of these words
I thought Ivy Bridge was a "tick" and the new Haswell architecture was the "tock"
http://www.intel.com/content/www/us/en/silicon-innovations/intel-tick-tock-model-general.html
I am going to finally spring for an upgrade to probably the 2500 or 2600 equivelent of IB (whatever those are again) around early June (a slightly delayed birthday present) and probably a mid-grade 7000 series AMD discrete GPU. I'll eye Haswell with jealousy, but unless something truely revolutionary drops from Intel along the way, I'll probably wait at least 2-3 years (maybe 4) before upgrading again (I got my core 2 duo 3 years ago this spring, though admittedly at the time I was buying about 18 month old tech when it hit and lowish end, this time I am going to go near top end for the CPU).
Beyond that, there'll be Skylake, which they're probably targeting for DDR4 and PCIe 4.0 support and is supposed to incorporate technology from the Larrabee project (instead of a CPU+GPU on-chip as we have now, the CPU BECOMES the GPU). That in turn, will be shrunk to 10nm with Skymont...
Best advice is to buy what you need, when you need it unless the new tech is < 3 months around the corner.
Isn't ivy bridge the tock? is it that much different from Sandy bridge in terms of architecture and technology?
Not alone in that. It does seem counterintuitive for a new architecture to be on the 'tock'.
They mostly come at night, mostly?
*ahem*
http://en.wikipedia.org/wiki/Intel_Tick-Tock
My laptop life cycle seems to be about 4-5 years, so I've got another 2-3 years to go.
I may build a new desktop before then, but probably not as I don't have the disposable income these days.
so do I... mostly....
