The Antec P280 has the same fridge-like looks as the legendary P180.
Antec is offering you the chance to see the forthcoming
P280 for the first time in the UK at Multiplay’s
i44 LAN event. The case will only be on sale here from ‘
the beginning of December’ but i44 is held from 18-21 November.
The P280 has the same minimalist fridge-like design as all Antec’s Performance One-series cases, harking back to legendary cases such as the P180. The interior of the new case isn’t compartmentalised, however, which allows the P280 to be less massive than its predecessors at 231 x 561 x 526mm (W x D x H).
There’s a PSU bay in the floor and two 120mm TwoCool fans in the roof, with another at the rear. It’s a shame to not see a 200mm fan in the roof, but possibly there will be room for a dual 120mm-fan radiator instead. At least the side panels have the same dual-layer stell/polycarbonate side panels as previous noise-deadening Performance One cases.
The door is triple-layer affair of aluminium, foam and plastic to again deaden noise; it’s double-hinged mounting means that the door can rest flush with the side panel and is hard to snap off accidentally. To test this for yourself (please, not too forcefully) head to the Antec/Kustom PC stand.
As well as seeing the P280 in the flesh for the first time, you can
play Minecraft for money at i44 and see the final eight players for the IGN Pro League 4 Uk qualifiers duke it out. You might pick up some tips for your own game. Or you might ignore them altogether to hang out with your mates: your call.
Are you going to i44? If so, will you check out the P280 and the other stands are you going to cram as much LAN gaming into one weekend as is physically possible? Let us know in
the forum.
22 Comments
Discuss in the forums ReplyAnd for more photos, there's a gallery over at: http://www.anandtech.com/Gallery/Album/1111
Looks good to me, might end up actually using this, or the new Solo II.
That aside, as Jipa said. Is a 200mm+ fan in the top really so difficult?
Well, there's that. I still love my delightfully silent Mini P180. Never had a problem with the top fan on low. Would be good to have the option of either 2*140mm or one 200mm+ fan.
http://www.antec.com/Believe_it/product3.php?Type=Mg==&id=Ng==
Much happier with a dual 120/140mm setup.
like the 2x120 fan placements. wonder if it's possible to put 2 240 radiators in this case? one on top, one on the HDD cage? that would make this an awesome watercooling case. there's more than enough room.
typical.
always been a fan on the range, but once i started attenting i-series i have to say i was less enamoured. they are not a great case to try and get to a LAN when you have no car and a very bad back :( hopefully this one will weigh a bit less than the usual baby elephant
Yeah they sure aren't, but then again, that's kinda the whole point...
Do like the clean lines. This maybe the case to replace my P180
