LGA2011 motherboards use a revamped heavy duty socket, which is very substantial
Intel has launched its long-awaited Sandy Bridge E processor today, which sport six Hyper-Threaded cores and a quad-channel memory controller.
The new CPUs are priced between £455 and £815 inc VAT ($555 to $990 ex tax) with the Core i7-3960X Extreme Edition demanding top dollar for its unlocked multiplier and 15MB of Level 3 cache. Combined with motherboard prices mostly in excess of £200 and a quad-channel memory kit, an LGA2011 system is a pricey PC.
The cheaper Core i7-3930K also has an unlocked multiplier, but only has 12MB of Level 3 cache rather than the 15MB of the Extreme Edition. It's also clocked at 3.2GHz (Turbo Boosting up to 3.8GHz) rather than 3.3GHz (Turbo Boosting to 3.9GHz).
A third LGA2011 CPU will launch in the first three months of next year too. Dubbed the Core i7-3820, it will be a quad-core Hyper-Threaded CPU clocked at 3.6GHz (boosting to 3.9GHz) with 10MB of Level 3 cache.
LGA2011 motherboards are also worth talking about too - to cater for the CPU's quad-channel memory controller, the DIMM slots are now located either side of the CPU socket in four- or eight-socket configurations. The large, 2,011-pin CPU socket has a metal backplate with threaded holes to provide a firm fit for CPU coolers; push-pins are finally banished.
However, this also means that most CPU coolers aren't compatible with Intel's new socket. We can confirm that Corsair's H80 and H100 coolers will work, in addition to Akasa's Venom Voodoo, Zalman's CNPS12X, Thermaltake's Frio Advanced and the Be Quiet! Shadow Rock Pro.
Be Quiet! has told us that it will be offering free LGA2011 compatibility kits that mount to its existing coolers (seen above), worth bearing in mind if you currently own one of it's
Dark Rock coolers and plan to upgrade to LGA2011. We'll have more information, including who to contact at Be Quiet! in the next few days.
Check out our
Intel Sandy Bridge E review.
39 Comments
Discuss in the forums ReplyAnyway, isn't the i7-3820 releasing at launch? Pricing seemed to be around that of Core i7 2600k/2700k?
incomplete of inaccurate? should that not be "or" and not "of"?
Seems like a contradiction in terms, lol
For the impatient.
Here is a review on Tomshardware
I'm not really bothered, slighty performance increase, nothing major, nice price hike.
Seem to be poor for extreme oc (in terms of consistency and clock speed)
With only being useful for a few benches.
http://www.coolercases.co.uk/gesher/x79_13.jpg
http://hexus.net/tech/reviews/cpu/32591-intel-core-i7-3960x-extreme-edition-cpu/
Nope, totally different socket, so no compatibility at all.
http://media.bestofmicro.com/0/5/314933/original/3ds%20max.png
http://media.bestofmicro.com/1/Y/314998/original/solidworks.png
Hard time for Bulldozer
Depends, maybe things will go back to normal for Intel which usually means ramped up stock by the end of January. Whether that replaces last year's batch depends on if they feel the need to cut prices of the current stuff.
http://www.anandtech.com/show/5091/intel-core-i7-3960x-sandy-bridge-e-review-keeping-the-high-end-alive
basically it's a server chip tarted up for the home pc market.
V. few people need quad channel memory and all that pci-e bandwidth ( desirable yes neccessary no ) or 6 cores especailly when it comes at such a price premium. In 4 months time 22nm 1155 chips are on their way which should be more overclockable ( and have native usb3 and quicksync). it really makes no sense what so ever to anyone but the most specialist of power users( even then I don't see anyone saying it will support ecc memory). I suspect intel has finally priced themselves out of the market. but if you need lots of cores then it's better than bulldudzer probably.
Agreed! :)
"Backwards Compatibility?! What is that?!" - Probably what an Intel spokesperson thought when reading your comment xD
I am still saving for my next build at the moment, but will have to see what the new revision's of these chip's bring when I have the money saved otherwise it will be Ivy Bridge for me.
lol at comment
Corsair Vengeance DDR3 1600MHz 24GB,
cant wait to try it out :D
I like they got rid of push pin mounts.. seems a whole lot smarter to go that way- beats drilling holes in backplates to make coolers fit
