Rumour: AMD's AM3+ CPUs delayed until September
Written by Paul Goodhead
May 31, 2011 | 10:50
Tags: #am3 #bulldozer #computex-2011-news #cpu #delayed #processor #september
Companies: #amd #intel
Rumours are currently circulating that AMD has been forced to significantly delay the release of its eagerly anticipated AM3+ CPUs until September, due to unforeseen stability issues.
AMD has yet to comment on the rumour, but an announcement regarding its AM3+ range of processors is expected at a press conference tomorrow. Tomorrow's event was initially believed to be for AMD to formally introduce the AM3+ CPUs, so it would be a major embarrassment for AMD to instead announce that the chips are delayed.
The reason for the delay, industry sources have explained to us, is that the first B0 stepping of the processors that AMD shipped to motherboard manufacturers in March was chronically unstable. This forced AMD to rethink the design of the processor die, a process which takes time.
AMD has now allegedly fixed this instability with the new B1 stepping of the AM3+ processors, we’re told, although the fix comes at the cost of not being able to overclock the chip. As a result, AMD is apparently hard at work on a second revision to the design, which should allow the processors to be overclocked.
These problems have pushed the back the processors' release date significantly, though, as motherboard manufacturers have only just started designing BIOSes for the processors as they haven’t had stable samples with which to work until now. However, one silver lining for AMD fans is that we were told that, apart from the known issues, the performance of the processors was good.
If the rumour is true, it would put motherboard manufacturers in the tricky situation of trying to sell AM3+ motherboards to the public without any AM3+ processors on the market for the next four months, however.
Do you have your eye on an AM3+ motherboard? Will this news make you rethink your purchase? Let us know your thoughts in the forums.
