HighPoint's RocketHybrid cards enable the creation of DIY hybrid storage devices.
Storage controller specialist HighPoint has announced a new host bus adapter card, which promises to turn any normal hard drive and SSD into a hybrid storage device.
The HighPoint RocketHybrid card combines the company's 88SE9130 SATA 6Gbps controller with a technology the company calls HyperDuo, designed to create hybrid storage devices that combines the best of both worlds.
When a hard drive is combined with an SSD on a RocketHybrid card, the company claims that users can access 100 per cent of the hard drive's storage capacity, while benefiting from 80 per cent of the speed boost offered by the SSD.
The 'hybrid drive' approach is nothing new in the industry, with storage specialist Seagate pushing its own brand of
SSD-equipped mechanical hard drives in favour of pure SSDs. However, HighPoint's approach means that any two devices can be linked to create a custom hybrid drive tailored to your own needs.
HighPoint has confirmed that two devices, the RocketHybrid 1220 and RocketPoint 1222, will be available when the range launches later this month. Both offer support for one SSD and one mechanical drive on a single PCI-E 2.0 low-profile add-in card. Pricing and initial performance figures are not yet available, however.
Do you think HighPoint's approach might be the best way to boost your system's performance, or would you rather have two separate drives? Share your thoughts over in the
forums.
19 Comments
Discuss in the forums ReplyIts price/performance will determine its worth.
The SSD is used as cache for the mechanical drive. Adaptech have had their maxCache products out for some time now and google will say that Raidon launched a similar product in february 2010.
In the raid solutions, you have ZFS that will do this with L2ARC (or Adaptec MaxIQ). A solution used by I.E. insulin maker Novo Nordisk in their protein database.
So why is this news?
Wars have been happening since the start of civilisation, doesn't mean a new, more exciting war isn't news :D
I am personally worried about the "cache" part, is it a volatile cache or is it stored on the ssd as you would any normal data. If it is volatile then I would sure hate to lose several GB due to a power cut.
Good SSD like performance with the capacity of a mechanical.
Or am i missing something?
Also, as a long time highpoint RAID card user: they're crap.
yup yup and theres worked fairly well too.
Same thought here, twice as many places to fail for a single drive
The silverstone thing on the other hand seems truly pointless to me - it just mirrors as much as it can from the HDD to the SSD but apparently without any clever software at work - the first 32 or 64 GB written to the HDD is written to the SSD, however big the SSD happens to be. It won't then check to see how often you actually use that data as against other date on the HDD
But if this thing has intelligent software that caches properly (e.g. like the seagate momentus, but you get to choose the size of the cache) but yet only costs £30 - I'd be interested. That would let me buy a 60-80gb drive, and hopefully it would just learn fairly quickly what game on steam I was playing at the moment and quietly shift that across to the SSD for me.
You'd be better off using the SSD as a boot drive and the raptor as a paperweight. Or trade it to some impressionable / stupid kid for a 2TB 5900RPM drive for all your games / data.
