The Eurocom Panther 2.0 now comes with the option of a six-core 3.46GHz Intel Xeon processor.
Eurocom has announced a new upgrade option to its Panther range of notebooks: the six-core Intel Xeon X5690.
The Eurocom Panther 2.0 isn't your average desktop replacement, featuring up to 24GB of triple-channel DDR3 RAM, your choice of dual-Nvidia GeForce GTX 480M 2GB cards in SLI or a Quadro FX 5000M 2GB graphics card, and Intel's 32nm Xeon X5690 six-core CPU running at 3.46GHz with a shared L3 cache of 12MB.
The Panther 2.0 also features up to four hard drives, offering up to 3.25TB storage in a RAID 0, 1, 5, or 10 configuration. Finally, a 17in 1920x1080 display completes the package.
The Eurocom Panther 2.0, as the specifications above attest, isn't designed around the same principles as your average notebook: weighing in at 5.3Kg, it's not a laptop to be carrying around with you as a daily-use machine. Rather, Eurocom positions its Panther range as 'mobile servers,' designed to offer a luggable alternative to fully-fledged rack-mount servers, complete with built-in - albeit brief - UPS.
The idea behind Eurocom's Panther range is to provide a reasonably portable system for those who require high-performance computing on the go, either as a demonstration unit for a sales team or as a hot-swap emergency replacement for a server engineer.
As you might imagine with such a brief, the pricing puts the Panther range out of the reach of the average gamer: a fully-loaded Panther 2.0 system with Xeon X5690, dual-GeForce GTX 480M 2GB, 24GB of RAM, and a single 320GB hard disk comes in at a wallet-busting £6,610.
Still, if you're looking for a laptop that will play Crysis, the Panther is probably your best bet, and represents a significant performance boost over the company's
Panther D900F Mobile Workstation.
Are you amazed at the amount of hardware Eurocom can cram in to a system and still call it a notebook, or is the Panther series nothing more than a niche product? Share your thoughts over in
the forums.
23 Comments
Discuss in the forums ReplyCan it play Minecraft?
clevo ;)
Oh... wait...
n0X1vyWU6bw
Because...
I'm finding it quite hard to empty my mind.
Im sure theres a joke in there about the software engineer being called rex
Yes but at the weekend he's called Susan!
these things have to get seriously hot.
Gaming on the go (and on a table), that is sweet.
The Xeon instead of a standard i7 is overkill though.
