The ViewSonic V3D241wm-LED features a 1080p panel and bundled shutter glasses for £330.
Viewsonic has officially launched its first 24in 3D monitor, but it's made some budget-trimming choices to keep the cost as low as possible.
The V3D241wm-LED runs at 1920 x 1080 and offers a claimed 20,000,000:1 dynamic contrast ratio thanks to the low-power LED backlight technology, along with 300 nits of brightness.
A 2ms response time is down there with the best of them, if not quite at the level of the company's 1ms 2D display announced
earlier this year, and a 120Hz refresh rate means that users should experience a minimum of flicker when using the display in 3D mode. A pair of 2W SRS speakers are built in to the unit, but if you're opting for a 3D monitor you've probably got a decent surround sound system already.
Interestingly, ViewSonic has taken the route of getting the display certified by AMD as suitable for use with its Radeon HD graphics cards. Speaking regarding the partnership, AMD's corporate vice president Darren Grasby stated that 'ViewSonic has been a great company to work with, and it is clear that it is dedicated to producing fantastic display technology.'
Sadly, that dedication doesn't extend to shelling out on the 3D glasses. While the V3D241wm-LED includes a pair of active shutter glasses to enable the three-dimensional mode when paired with a compatible graphics card, the company has cut a few corners and opted for a wired set, tethering the user to the monitor.
The ViewSonic V3D241wm-LED should be appearing on your favourite resellers' websites any day now, with a recommended retail price of £330.
Do you think that ViewSonic has a winner on its hands, or does the AMD certification not distract you from the disappointing wired shutter glasses? Share your thoughts over in
the forums.
15 Comments
Discuss in the forums ReplyLol I'm asking for way to much aren't I? Should probably throw OLED into that mix too with all the likely hood of that spec coming anytime soon.
Any solid monitors coming into the bittech offices in the near future? And no I don't count this.
Toshiba is working on a 3d screen that wont require wearing any form of glasses when that goes mainstream then you will really see 3d take off.
...And probably not until. It's what would persuade me ot think about investing in the tech.
...but the compensation for what are basically weak sunglasses in the color reproduction makes the screen rubbish for 2D usage
Agree with this. Normal HD TV's and monitors are getting cheaper and cheaper and they need something to tout as 'the next big thing'. Unfortunately, i don't think 3D is it (certainly not with the current technology limitations).
Many find the pros outweigh the cons for 2D gaming.
120Hz monitor
Pros
Virtually no input lag.
Less trailing on motion (more frames means less of the sample and hold effect)
More responsive and smoother (due to having more images 120 per second rather than 60 per second)
Cons
Black levels can't match IPS
Colour reproduction can't match IPS
Poor viewing angles
A 120Hz IPS would be the best of both worlds.
good thing no one's forcing us to buy them then.
But I won't be buying until they hit 27 or 30"
If it is just the Hz side which holds it back, then why can't I use my 600Hz LG non-3D Plasma as a monitor with a compatible GFX card and 3D glasses?
http://en.wikipedia.org/wiki/Contrast_ratio#Dynamic_Contrast_.28DC.29
