Zotac's latest card has three DisplayPorts and a DVI connector - meaning quadruple-display support.
Zotac has announced what it claims is the world's first Fermi-powered graphics card capable of running four monitors simultaneously, in a clear attempt to catch up with AMD's EyeFinity.
The Zotac GeForce GTX 460 3DP features, as the name suggests, three DisplayPort connectors along with a more traditional dual-link DVI conector, giving the card the ability to run four independent displays with a combined resolution of up to 6,400 x 1,200.
While it isn't quite as impressive as the
six-screen layouts we've seen AMD's EyeFinity technology running, it's still impressive stuff - and gives fans of the green camp a taste of things to come.
Carsten Berger, Zotac's marketing director, claimed the move came as "
quadruple-display computing is becoming more popular for gaming and office use," and confirmed that the card will come bundled with a copy of
Prince of Persia: The Forgotten Sands.
Aside from the multi-monitor support, Zotac's latest card is a pretty standard GeForce GTX 460. The clock speed has been given a boost to 710MHz to better cope with multiple monitors, and there are hints that the card will have 2GB of GDDR5 RAM - although Zotac's official specs refer to a 1GB version. Whether this means there will be two editions launched, or if it's just a mistake in the box art, remains to be seen.
The card will be hitting shelves soon, but Zotac has yet to confirm UK pricing.
Do you think that driving four monitors from a single GTX 460 is a realistic proposition for gaming, or should Zotac have dropped the specs and made it a more attractive buy for the office market? Share your thoughts over
in the forums.
18 Comments
Discuss in the forums Reply- what displays are needed to run 4 displays?
do you need 3 DP compatible displays on the DP ports or active adapters like on regular ati cards if you want to drive more than 1 ... 2... ?
(ati cards need a DP monitor or active adapter if you want to run 3 displays on a non-eyefinity-dedicated card)
- does an DVI monitor with a passive adapter run on the DP ports AT ALL?
- what resolution is supported on the DP port if there are not 3 displays connected?
- what resolution is supported on the DVI port if there is a monitor connected to the DP ports... at how many monitors it drops to 1600x1200?
what does this mean? that you can only span a game over 3 monitors and not 4?
what now zotac... 4 or 3 ...?
19"-24"-19" as they are about the same physical height
1280x1024 - 1920x1080 - 1280x1024
would give 4480x1024
I mean, they are more popular than 16:9 monitors now. And cheaper!
Was that sarcastic?:?
yeah and not to forget that all of those have display ports!
Dell is having an incredible deal on 20" LED monitors at the moment: 1600x1200, 1ms G2G, 120Hz S-IPS panel, 360° viewing angles, 120,000:1 Dynamic Contrast, Multi connections (DVI/VGA/HDMI/DP/Comp/SVid/DB23), <20w power consumption, all for $140 delivered.
And Samsung has recently announced that they will be releasing a 4:3 panel with ultra-thin bezels for gamers.
Mark my words, 4:3 is the ratio of the future!
http://i54.tinypic.com/mlt36f.jpg
All that to say that a 460 is not a bad start.
If only :D
16:9 is terrible for viewing photos if you have a mix of wide and tall photos.
