Intel's roadmap suggests 22nm and 15nm Atom chips, but doesn't provide a timescale.
Intel has unveiled a roadmap for the Atom processor which shows the netbook- and latterly mobile-oriented chip shrinking to a 15nm process.
Unveiled at the Intel Developer Forum, and first spotted by
CNET, the roadmap suggests that existing 45nm and 32nm product lines will give way in the future to a whole raft of chips based around a 22nm process.
After exploiting that for a while, Intel plans to move the whole kaboodle over to a tiny 15nm process, while at the same time increasing the number of Atom chips across the entire range.
At the 45nm process size, there were four Atom processor families: the N-series, designed for use in netbooks; the D-series, aimed at nettops and low-power desktops; the Z-series for handheld devices; and the CE series, which found its home in consumer electronics like set-top boxes and interactive TV systems.
The move to 32nm added another line to the Atom range: the specialised E-series, designed for embedded computing systems.
According to Intel's roadmap, all five product lines will be making the transition to 22nm and 15nm in ever-increasing volume - but unfortunately, if somewhat predictably, Intel hasn't given a timescale on when the shrunken chips will be hitting the market.
Instead, the company has placed a simple arrow at the bottom of the graph, pointing to the right, labelled "
Forecast," helpfully ruling out the possibility that it was to develop time travel technology and launch the 15nm chips some time in the 1990s.
A process shrink will help increase speeds and reduce power usage - something that Intel will be keen to do as soon as possible in order to better compete with low-power chip expert ARM.
Are you impressed that Intel is looking to 15nm already, or does a slide prove nothing about how prepared the company is to face the challenges of such a small process size? Share your thoughts over in the forums.
22 Comments
Discuss in the forums ReplyThe interesting thing for me is that the 11nm-15nm transistors are the wall that Moore's law will run up against. How are they going to get past it?
I think quantum and carbon based systems are the two biggest contenders right now, but we're looking at 15-20 years until the limits of 15nm SOI become felt, so there nay be other tech out there that fills the bill.
That's like saying: "BREAKING NEWS!!! Samsung plan to build TVs with higher resolutions... in the future." :|
There won't be a 32 for mainstream parts. Only E-series.
Intel will keep the current process generation until the end of next year, so the original Atom core will have had a four year lifespan! 22nm should see a considerable power drop vs 45.
The news is that Intel intended to greatly expand the Atom core across many products - CE mostly - so instead of future products containing ARM chips like they do now, Intel wants you to be using IA-cored products in MP3 players, Blu-ray, TVs, White goods?
I thought 8nm was the absolute minimum...
A lot of people thought XXXnm was the absolute minimum :D
Meh, without a timeframe, this is no news. Sure, at some point in the future, they'll need to get smaller. Wow, i mean, just wow. :D
In the future, PCs will be able to play Crysis!
Fixed.
Ah, no. That's 45 on the Nonce Meter scale. Easy mistake to make.
Ariel? :D
No...Persil.
