The new 20nm process from Hynix promises better yields and double capacity chips for future SSDs.
Hynix has announced that it has begun mass production of 64Gb NAND flash chips based around a 20nm process, opening up the possibility of another leap in SSD capacity.
The company's latest 20nm process means that it is able to produce 64Gb NAND flash chips the same physical size as its previous 32Gb models - theoretically allowing manufacturers using the older models to drop-in the new replacements for an instant doubling of capacity, or giving them the opportunity to use half as many chips for the same capacity in order to reduce costs or make power savings.
Pricing should improve as a result of the move, too: the company claims that its 300mm fabrication facility can get around 60 per cent better yields than the previous 30nm process - and better yields mean better prices, although how much of this saving might get passed down to the consumer level remains to be seen.
Dr. S. W. Park, the chief technology officer at the company, said that the move means that Hynix is now "
enabled to provide customized, high performance products in a timely manner which perfectly suits mobile solutions including smartphones, table PCs and others."
So far no companies have announced that they are planning to use the new 20nm chips in their products, although Hynix has announced that it will be continuing its partnership with Israel-based SSD manufacturer Anobit and is looking to upgrade its devices to the new chips by September this year.
With solid-state storage becoming increasingly popular, moves like this are required in order to get the cost-per-megabyte down: while current models offer the capacity and performance required of, say, a boot drive, they're still priced out of the reach of many - especially if you're planning on using them for mass storage.
Are you thinking about holding out on an SSD purchase until 20nm becomes the norm, or are companies switching to Hynix's latest chips just likely to keep the cost savings for themselves? Share your thoughts over in
the forums.
23 Comments
Discuss in the forums Replywish the new SSDs with these would come out at arround September (with the accompanying lower prices too) :P
Or was the 30nm node on 200mm wafers and the 20nm node on 300mm?
An increase in capacity = win for us
A corresponding increase in price (well you are getting more space, it would only be logical)...........
Agreed. I don't care about the new 512GB SSDs, or having mass solid state storage., I want to see the mainstream 64, 128, and 256 GB SSDs come down in price and up in performance. Two of the new 64GB memory chips with a good controller (Sandforce or whatever the good one is), around the $100 mark, and I'd bite.
I went "WTF?" at this sentence till I realised that 300mm referred to the diameter of the silicon wafer... :P
agreed ^_^
that means if a 500GB ssd cost £100
that it would be 0.01953125p per MB
this is impracticle it should be per GB which would be 20p per GB
but im not buying till down to under 8p per GB
Anything to make a 64GB SSD more affordable is great. I don't need 1TB SSDs, I run a desktop PC not a bloody server with massive I/O! :|
Yes, even physical HDD's only got that cheap really last year.
I might begin to consider a small SSD when they get to £1/GB, but at present I can't really justify paying that much :(
