The Inno3D GTX 470 and GTX 480 'Black Freezer' editions come with factory-fitted waterblocks.
Inno3D has revealed the first images of its upcoming Black Freezer GTX 470 and 480 graphics cards which feature a pre-fitted waterblock.
The rather neat looking cards have a near-full PCB waterblock factory-fitted by Inno3D, making them super-easy to integrate with an existing watercooling system without voiding the cards' warranties - and without the need to purchase third-part add-ons.
Strangely, the cards appear to still be double-slot in width - meaning that they'll take up both your PCI-Express slot plus the slot next to it - despite the waterblock having top-mounted connections and requiring no airflow over its surface. Whether this is due to complex internal construction that will ensure optimum performance from the waterblock is something that will have to await thorough testing.
Sadly, while Inno3D is eager to whet peoples' appetites with a sneak peak, it's being a little more cagey on the details: according to
Fudzilla the company is being unnecessarily tight lipped about this upcoming release. What
is known is that the Black Freezer watercooled cards will be available with both the Nvidia GTX 470 and GTX 480 GPUs, but the precise specifications of the cards are as yet unknown.
Another unknown is the construction of the waterblock: while guesses are made as to the material - most likely either aluminium or some form of plated copper - the company is again keeping quiet until closer to the launch.
Likewise, the company has yet to announce availability or - crucially - pricing for either card.
Does the idea of a pre-fitted waterblock take some of the DIY fun out of the whole watercooling concept for you, or could you see yourself in the market for a no-faff watercooled graphics card? Share your thoughts over in
the forums.
20 Comments
Discuss in the forums ReplyEvga H20 gtx 400s
What i wanna see is some reviews of these beasties.
Im just curious about it's overclocking abilities...:o
But it is still hot, even under watercooling
Looks good but it will be an awful lot of money for something that isn't even the quickest card (something which could be said about the standard GTX480 - uk shafting, sorry pricing only).
£650+ im guessing?
@Tulatin: And they come with a single slot backplate :) don't know about the Inno3D ones though.
http://imgur.com/JDxFm.jpg
http://imgur.com/JRW7X.jpg
Images from EvilClocker @ XS
If all you cre about is raw power then why would you forgo the HD5970 for the slower GTX480?
(Unless you mean specifically for CUDA?).
It's nickel plated. But that doesn't change the fact that the block is shite.
