Chipsets with USB 3 support aren't listed in any Intel roadmap until 2012, with SATA 6Gbps arriving late next year.
While we've managed to get hold of enough hardware to take a first look at both
USB 3 and
SATA 6Gbsps performance - and
motherboards featuring one or both are filtering through, Intel has yet to make either new storage standard a part of its chipset line- up.
Our sources here in Taipei tell us that Intel has no plans to integrate USB 3 into its chipsets until 2012 at the earliest - there are no new platforms due this year, and next year's roadmaps currently show none featuring USB 3. Apparently Intel plans to make a USB 3/SATA 6Gbps all-in-one chip for optional use by motherboard manufacturers on its products, however it’s currently finding it difficult to get the pin-count down to an appropriate size.
In some respects this is good news, though because it means market diversity. Companies such as Marvell, NEC, VIA and Realtek can offer alternative USB 3 and SATA 6Gbps chips, however it's something that needs to be well implemented by the motherboard designer - high bandwidth devices need a connection to match: not just a bog standard x1 PCI-E lane. Recently in our own labs, we’ve found that testing the latest SATA 6Gbps Crucial SSD can saturate the Marvell controller currently used on all recent Intel boards. As such we’ve had to opt for an AMD system with its latest SB850 chipset that natively provides the SATA 6Gbps ports.
SATA 6Gbps is currently slated not to arrive in the Sandy Bridge refresh in Q1 2011 (which it appears has slipped from Q4 this year), however it will likely be integrated into the Q3 2011 refresh of the high-end X58 platform, currently
being called ‘X68’ by many in the industry.
Does this affect your upgrade plans? Will USB 3 become a critical buying decision in the future and would you buy an AMD system instead for its native SATA 6Gbps support? Let us know your thoughts
in the forums.
15 Comments
Discuss in the forums ReplyI'd much rather have everything in one chipset rather than several others. I know Windows is good at getting drivers these days, but there are power usage and cost issues too.
PCIe bridge chip to convert 4x PCIe 1.1, no bottleneck and affordable :)
AMD doesn't have native USB 3.0... It uses a Nec PCI-e-USB3 controller... It's the same thing. I was just expecting that by 2011 USB3.0 would be "inside" the NB/SB... not in another chip
Compact Flash cards are going past 100mb/s now and I am sure SD cards are being held back a fair bit by USB2 as i can't get much more than 22mb/s out of my card.
+1 This is a viable solution. Thankfully my rig is still up and running and here's hoping it stays that way until some board comes with every new feature announce nowadays.
Flash USB sticks are limited to speeds far below that of USB 2, and for external HDDs we got both FireWire and eSATA as faster alternatives. I honestly can't think of a single device I would get the USB 3 version of.
Light Peak should be smaller, faster and still support USB 3 protocol as it's just a carrier. I am actually looking forward to seeing what it can do.
