Marvell's latest SSD claims 2gb/s sustained throughput and 200k IOPs from MLC NAND Flash.
COMPUTEX 2009: Marvell will smash the performance of other SSDs with its latest PCI-Express SSD which claims to run at a huge 2GB/s
sustained throughput and can handle 200,000 IOPS from
MLC NAND Flash.
The 88SE9480 is a quad channel PCI-Express to S-ATA controller that connects to four 88SS8014 SATA to NAND Flash controllers, which feature wear-leveling technlogy and ECC hardware. The product is clearly aimed at server and workstation class environments, but when we asked Marvell if the 88SS8014 S-ATA to NAND flash would be available as a purchase on its own for 2.5in hard drives the rep explained it was possible but there were no concrete plans.
The current pre-production hardware is separated over two cards right now, with S-ATA connectors linking them together, and we can clearly see the space for four DDR2 SoDIMM memory slots on the upper card for cache, however no specific sizes supported were yet given.
Fancy some Marvell marvel? Let us know your thoughts, in the forums.
2 GB/s? Even better!
Do I need that? Nope. :(
If this goes through...
CHEAP SSDs FTW!
It looks pretty dodgy in buildup though. I can spot 6 different PCBs on that picture, although it's not that clear.
It also looks to me that the RAID-controller card that this thing is built around has a capacity for 4 more SATA drives. With good scaling that could amount to 4GB/s, though what anyone would use all that for is a mystery to me.
I think it's unfair to announce these things as a "card" though, as if it's a single product. It's basically an entire storage subsystem with a RAID card and four high-end SSDs attached to it. A self-built array of equal cost will perform pretty similar i think, so i'm not completely over the moon.
Impressive tech-demo though, i hope the technology trickles down into some actually buyable products soon :)
And I couldn't exactly see what's so revolutionary. Is it the SATA to NAND controller? How does FusionIO get their numbers?
