SanDisk has this morning announced its third generation family of solid state drives at CES.
CES 2009: SanDisk has this morning announced its third generation family of solid state drives at CES.
Based on multi-level cell (MLC) NAND flash technology, SanDisk claims the drives establish new benchmarks in performance and value in the industry.
The G3 SSDs are available in both 2.5in and 1.8in form factors in 60GB, 120GB and 240GB capacities. They'll be known as the C25-G3 and C18-G3 in their various guises.
SanDisk says that the drives deliver read and write speeds of 200MB/sec and 140MB/sec respectively. The new drives also provide a Longterm Data Endurance technology that allows 160TB to be written to the 240GB version of the drive which, according to the company, is equivalent to over 100 years of typical use.
In terms of pricing, SanDisk doesn't disappoint with MSRPs for the 60, 120 and 240GB drives set at $149, $249 and $499 respectively.
SanDisk added that the drives will be available for DIY enthusiasts via SanDisk's website.
Sound promising? Tell us
in the forums!
7 Comments
Discuss in the forums ReplyDo you think these are 64GB with a bit lopped off for redundancy, or have they just done something a bit odd to break from the usual 64, 128, 256GB trend?
I'll wait until they've had some real-world testing (i.e. user feedback after weeks and months) before plodding down any bills for such drives.
Is this an MLC problem as well as SLC? Or is this likely just a problem due to the controller used (Sorry, I can't remember which SSD it was)?
Basically what you are saying is true. Writing data is slower the second time, but ONLY on SLC. It's still going to be fast though...
i think i'll be splurging on the 60Gb soon.......... wow............... i mean........
by the end of this year im sure 120Gb is below $99................ its so exciting to have the one single most troublesome bottleneck in a PC is getting a huge makeover :)
