OCZ's new Throttle has eSATA to get your data off it just that-much-faster.
Donkey's years ago OCZ mentioned to us about how it was developing a Firewire flash drive.
Faster speeds! the PR claimed,
USB is so limited!
Well, that time came and went and while it was a product that never made it out of development because of driver and controller issues, OCZ seems to have cracked a better and faster goal - the eSATA flash drive.
It's not
the first eSATA flash drive by
just a few weeks, but it is currently the fastest.
Dubbed the Throttle, this little flash drive is the same size as your USB thumb drive so it'll fit right in a pocket or on your keys, yet, instead of being limited to ~35MB/s from USB 2.0 this little devil claims to have a read speed of 90MB/s. Write speeds are still pretty limited at 30MB/s, so nothing much there has changed from "fast" USB drives, and it does mean you need a PC with an eSATA port to take advantage of it. There is a mini-USB included on the Throttle too though, just in case the PC you want to use it with is too old or crippled to have a fancier eSATA connection.
Available in 8GB to 32GB capacities, you've got a dual layer DVD to Blu-ray's worth of data at your finger-tips, although if we're willy-waving then we have seen 64GB flash drives knocking about these days.
It's got a 2 year warranty and will be available from $34.99, $54.99 and $94.99 for 8, 16 and 32GB versions.
Fancy yourself a super fast flash drive to carry around with you? Or is the write speeds or eSATA not doing it for you? Let us know your thoughts in
the forums.
15 Comments
Discuss in the forums ReplyDamn good prices, those. I approve.
Either way ZOOOOOOOOOOOOOOOOOOOOOOM!
Cast your mind back ... 3 years when USB ports were found only on the back of a PC!
One end has eSATA, the other a mini-USB. A spare USB port is still required to provide the power.
Really? Well that's dumb. I was hoping for just plugging up the eSATA port.
It's got a limitation, sure, but this is definitely cool. Having a little SFF machine booting from this would be wicked. Hopefully they'll ship a small A->BMini cable for just looping around to a close USB port (power pins only.) It'd only have to be about 100mm long.
Or just go into a internal header would be best
Kimbie
But if it's connected to an internal SATA port (must be possible?) then yes, a header would be a better idea. Although I'm sure, given the design of the device, you won't be getting a B-Mini -> USB header cable with it. ;)
would be relatively easy to make one though, I can see this being a really good device to use as an internal quick-boot drive.
Whether or not that means, it only needs the esata connection, or it still considers plugging in the usb and esata plug and play.
What about that drive that was released before? the Kangaroo one or something, I dont remember that one using a separate plug for power.
