AMD intros one click magic trick utility
According to Brent Barry, AMD's gaming strategist, the company's Fusion for Gaming utility will fix the problems with PC gaming by shutting down background applications with its one click magic trick.
AMD last night unveiled its Fusion for Gaming utility during a live webcast. Brent Barry, AMD's gaming strategist, said that it's is designed to make gaming on AMD-based systems a better experience with the click of a button.
In fact, he went so far as to say that it "fixes the problems" with PC gaming by shutting down "anything that might cause your PC to become unstable or insecure." That's a pretty big claim to make.
I'm sure many of you have been through the days of rigorously optimising your Windows installation to free up memory and CPU cycles to improve your frame rate in a game that doesn't quite run as smoothly as you'd want on your system. At the same time, you've probably encountered problems when you've shut down processes that were, in actual fact, needed by your OS.
Barry said that AMD's Fusion for Gaming utility achieves the same in a much smarter way, as it lets users turn off unneeded processes and background tasks with the click of a big and rather garish looking button - indeed, my initial impression was bloatware. That was made even more apparent when you click the button, as your ears will be infected with a whooshing sound as it speeds up your system.
However, looking deeper into the application revealed that it wasn't quite as bloated as those initial impressions would have you believe. There are several modes available, depending on how confident or skilled you think are.
Basic mode is a fairly low-level and tame optimisation that shuts down background processes and increases the CPU performance using AMD Boost, which shuts down some of the things that happen inside the OS that you don't want to disturb your game. Barry cited examples like Cool'n'Quiet and power state switching. With the basic mode, Barry said that these optimisations alone would increase gaming performance from anywhere between two and five percent depending on the PC's specifications. Obviously, with higher end machines, you'll see less of a benefit.
There's also advanced mode, which does the same as basic mode but in addition, it's more aggressive in what it shuts down and will close applications like your web browser, email client and so on. Barry did say that if a save prompt window appeared, the application wouldn't be forced to close, so there's no chance of you losing your Word documents when you decide to run off for a quick game of TF2 when the boss isn't looking. What's more, it also overclocks the CPU, GPU and hard drive in your system; it wasn't clear how AMD is overclocking the hard drive - AMD mentioned it was applying some tweaks to the southbridge, but didn't go into any detail.
Finally, AMD has implemented an expert mode to keep those that want to tweak things further when making your PC go whooooosh with excitement. Here, you can adjust how far your CPU and GPU are overclocked, and also what programs are stopped. For example, if you wanted to leave a voice communication application like Skype or TeamSpeak open, you can tell the utility to ignore it when it's going about its business. In this mode, AMD reckons that you'll see around ten percent more performance in games - whoosh!
There is a snag though - AMD said that the software will only work on AMD-based systems and made it clear that this not only required an AMD CPU, but also an AMD GPU and motherboard chipset. The application won't work on Intel-based systems with an AMD GPU installed for example, which rather limits its appeal for many enthusiasts seeing as they are the preferred choice at the moment. What's more the application is only officially supported on Windows Vista 32-bit at the moment - Barry did say that it would run on Windows XP as well, but it is not supported by AMD at this time.
When asked about 64-bit compatibility, Barry said that the company has developed the application "to work on Windows Vista 64-bit," but it is still going through the validation process with overclocking CPUs and GPUs in particular. He said that the application is probably a month or two away for 64-bit users.
The application is part of a corporate branding strategy that is "AMD’s way to express how we blend our customers’ needs, dreams and desires with our unique passion for enabling innovation,” says Nigel Dessau, AMD senior vice president and chief marketing officer. In other words, it's AMD's way of demonstrating why buying an AMD CPU, GPU and chipset and running them in the same system is better than the sum of all parts. So, Spider didn't last long then? Whoosh!
21 Comments
proxess 18th September 2008, 14:51 Quote
An application for children! Real e-peeners ... err ... men ... tweak their computers manually!
naokaji 18th September 2008, 14:53 Quote
Just buy a computer thats fast enough to start with... oh wait, amd doesnt sell that.
Paradigm Shifter 18th September 2008, 14:56 Quote
Hm. Pity I never have Word/Excel/Outlook/Firefox/whatever running when I game. Shutting down background processes could be a good idea - provided it isn't something like AVG8, where as fast as I kill it, it restarts itself - but that program would really need to know what it was doing if it was going to start fiddling with shutting down background processes or some interesting stuff could happen.
I can see overclocking CPU/GPU, as well... but the HDD? What are they going to do, make the platters spin faster? Considering how ridiculously bottlenecked HDDs are by the nature of their technology in comparison to the bandwidth now available to the SATA bus... it's marketing. Little more.
Come on, AMD - focus on giving us awesome new hardware (like the 4800 series) rather than this nonsense software just so you can make a press release.
mrb_no1 18th September 2008, 15:02 Quote
i think paradigm shift summed it up there, this allows amd to make a press release.
i can see it appealing to those who buy a pc of amd parts as they probably wouldnt bother tweaking their pc's, as proxess puts it, "like real men" so it now makes their system that much better, potentially.
My thoughts are with naokaji on it though, most enthusiasts will already have a quick enough system but then the software isnt aimed at readers of bit-tech, its for the people who say ooooooooooh when they watch pc world adverts. interesting idea from amd/ati non the less!
peace
fatman
DXR_13KE 18th September 2008, 15:52 Quote
"LOOK MOM, I'M OVERCLOCKING MY HARD DRIVE!!!"
TreeDude 18th September 2008, 16:09 Quote
This would be a neat little app if it were not so limited. When I first started PC gaming I had a mid-range (Athlon XP 2600+, 1gb DDR 266, 9600pro) system that I used to shut down background process manually to be sure I was running as fast as I could. This would have made things easier.
Now however I have a C2D and 4gb of DDR800. This would not help at all. But for people who have those mid-range systems like I had it may give a boost.
War-Rasta 18th September 2008, 16:24 Quote
lol I was about to post that very same line!
I agree with TreeDude. I used to do the same thing back when I had my old 800 MHZ Pentium III system with a blazing fast nVidia TNT 2. Something like this would have made things easier to have a list of processes to shut down with a single click instead of shutting them down individually.
Tim S 18th September 2008, 16:51 Quote
I used to have a batch file that started all of my processes back in the day... I'd start Windows bare with not much more than networking enabled so that I could game on a completely clean system after a reboot. Nowadays I've got more than enough horsepower to not care. Damn, 4GB is so cheap these days and no game really uses 4GB yet.
FeRaL 18th September 2008, 17:09 Quote
I remember back in the good old days of DOS when you pretty much had to make a boot disk (floppy) and tweak the autoexec.bat and config.sys files to get your system optimized to play game on your 386 or 486 processor... Anyone remember these old commands?
DEVICE=C:\Windows\HIMEM.SYS
DOS=HIGH,UMB
DEVICE=C:\Windows\EMM386.EXE NOEMS
Tim S 18th September 2008, 17:13 Quote
DOS=HIGH,UMB
Now they were the days... thinking about that brings back fond memories of the very early days of gaming for me. The time I was referring to was when I first moved from Win95 to Win98SE on my gaming rig - they were fun times too.
tylerpestell 18th September 2008, 18:16 Quote
DOS=HIGH,UMB
Ah yess ... those were the good 'ol days of gaming. Day of the Tentacle, Monkey Island, Indina Jones all those DOS based adventure games were awesome. Oh and "The Dig"!!
Amon 19th September 2008, 01:36 Quote
Glad to see at least somebody take up on DirectX 10's original concept from who knows how many years ago. Now, all we need is an operating system suitable for gaming.
MajestiX 19th September 2008, 05:06 Quote
i'm bringing the turbo button back... YEAH, UHHH
those intel don't know how to act... yeh
and so on...
Joeymac 19th September 2008, 05:07 Quote
Hmmm. You could do all that setting up and so on and press a button every time you want to load a game. Or you could get a faster Intel CPU in the first place, leave everything running and get the same gaming performance. Or something like that :P
I hate shutting things off for gaming, you shouldn't have to. What's the point of quad cores if you aren't going to put them to some work with multi-tasking. Sure it'll take a percentage point or two of frame rate if you are lacking some ram and play at 1024x768, but who does that? Having photoshop open with a GB file is one thing, but leaving a few firefox windows, a music player, email client, explorer window and some downloading software running shouldn't be a problem, even on a dual core system with 2GB of RAM.
johnmustrule 19th September 2008, 07:32 Quote
SOMEONE POST A REVIEW!!!!! LINKS PLZ
[USRF]Obiwan 19th September 2008, 08:10 Quote
DOS=HIGH,UMB
Aaah yes! Damn I am getting to old for this shit. Those where the days. (Dos/4GW anyone?) Hey! remember playing doom where you could adjust the screen size to have a smoother play? Why not bring back this part of nostalgia in games. So people with slow system just resize the rendering size on screen with the [-] and [+] on the keypad of their keyboard. if you cannot play it full screen you know your system is getting slow, but hit the [-] key and reduce the screen size and hey you can at least play the game smoothly.
alexandros1313 19th September 2008, 10:05 Quote
I think it's a great idea, but it needs to be available to everyone and not just AMD users.
p3n 19th September 2008, 10:43 Quote
Yes please interfere with my system mr AMD - have fun wasting money supporting that you arent getting any of my business..
Bauul 19th September 2008, 11:04 Quote
Lol, I remember that well. Screw resolution changes, this is the future!
DarkEditioN 20th September 2008, 01:32 Quote
I am sure Intel will think up something even better - Go go Intel, don't disappoint me :D
frontline 21st September 2008, 10:36 Quote
Not really a surprise that it's for AMD systems only, since they know the hardware capabilities, obviously. Agree that it has limited appeal though, although if they can get the hardware out to match the likes of this and their very sexy overdrive utility, then they may be on the comeback trail.
