Plenty of Nehalem boards on show
Intel Nehalem workstation and server boards were also on show
Despite the fact that we had the corporate "we can neither confirm nor deny Tylersberg will be called X58" speech from Intel itself, it seems pretty obvious from the plenty of manufacturers on show at its own stand that it will be the intended name.
First off, the Abit IX58-MAX - don't take the cooling (on any board) too seriously yet, we're sure it'll get heatpiped eventually. Abit looks to have gone for a standard eight phase power regulation rather than digital PWMs this time although the rest of the board looks typically Abit in style - blue PCB and black slots.
Plenty of Nehalem boards on show Plenty of Nehalem boards on show
Both Foxconn and Asus had their mainstream boards on show - no doubt wanting to keep their respective gaming series under wraps until nearer the time of launch. Many boards are now featuring four x16 lanes because the X58 chipset has 36 PCI-Express 2.0 to play with, so four x8 slots and an x4 is certainly viable now.
Gigabyte again makes a familiar looking board, however there are a couple of odd SATA placements at the bottom. The Intel reference design has a quite strange northbridge placement but otherwise looks as unremarkable as usual. We're seeing less and less PCI slots on these motherboards in favour of PCI-Express x1 instead - how soon until they are phased out entirely like EISA was back in 2001 with Socket A Athlons and later Socket 370 Intel Coppermines?
There are also many server boards on display - X58 will feature on the very high end so the performance also overlaps here. Because of the direct connect nature of the CPU to memory there is more PCB space and these boards look similar to AMD Opteron now.
Do you really want one? Do they look how you'd expected? Let us know your thoughts in the forums.
Quote wuyanxu 6th June 2008, 21:22
interesting core orientation on the Intel board.
hope we'll still have as much freedom in heatsink mounting direction as the current square ones.
Quote Redbeaver 6th June 2008, 21:38
where's the DFI ones??????
Quote 500mph 6th June 2008, 21:39
I wish more boards were like the intel board. It goes with airflow very well.
Quote pistol_pete 6th June 2008, 23:09
What's the point in new motherboards if they aren't pretty? More copper!
Uh, otherwise the heatsink mount holes look to be square... good, any orientation.
Quote Icy EyeG 6th June 2008, 23:54
Do the Dual Processor Nehalem boards use FB-DIMMS?
Quote DXR_13KE 7th June 2008, 00:02
i think it is time for pci to die....
Quote RotoSequence 7th June 2008, 00:15
DFI has always been slow to the new chipset party. Expect them to be fashionably late, to the point of X68 being on the verge of release :p
Quote Hamish 7th June 2008, 00:16
perhaps you should tell the expansion card manufacturers that :p
Quote Goty 7th June 2008, 02:22
It's nice to see some high-end Intel chipsets that don't require massive northbridge heatsinks and a ton of heatpipes to cool it, again.
Quote 1st time modder 7th June 2008, 05:24
is it just me or are the heatsink mounting holes excessively far away from the socket wall? ... and PCI still isn't used to its fullest bandwidth. I agree with you Goty, nice to see it aswell, silence and functionality are key. Am curious to hear the full detailed specs of X58 and its partnering components.
Quote Bindibadgi 7th June 2008, 09:39
Don't be too sure - these are very very early boards.
RE: FB-DIMMs, you know, I completely forgot to ask but I would say no - they are simply Registered ECC DDR3 because they've no need to be fully buffered anymore as there's no central MCH and no need to reduce the trace count.
Quote Djayness 7th June 2008, 10:38
Has asus ever made a board, more bland, more ugly than that....looks like someone chose a terrible pcb colour.
Quote Bindibadgi 7th June 2008, 12:15
Think about it this way - if Intel asks your for support, you will want to be there. However, by being there all the competition knows what you are doing, so this is the only way Asus gets to win at both keeping its cards close to its chest and providing support.
Quote naokaji 7th June 2008, 14:20
I'm not sure just how many heatpipes and how many tons of copper color painted aluminum they will slap on those boards, afterall x58 should use far less power due to Nehalem having IMC.
That they neither deny nor confirm that x58 will be called x58 is rather stupid though, especially considering they have boards with x58 in the name at their own stand.
Quote Cupboard 7th June 2008, 19:12
Very odd Intel board... everything is the wrong way round and the memory slots have three of one colour and one of a different colour. Is this catering for some processors have 3 channel memory (the 3 blue slots) and some having 2 (some other combination)?
And I suppose x58 will be cooler running now it doesn't have to do memory controlling.
edit: the post doesn't seem to link here, though I may be being stupid.
Quote Goty 7th June 2008, 19:14
That was my line of thought, too. If Intel still can't get the power consumption of their chipsets down after removing the vast majority of the logic from their northbridge, that's pretty sad.
Quote ssj12 8th June 2008, 00:14
nVidia needs to definitely license intel SLi tech so they can get SLi into these boards
Quote Icy EyeG 8th June 2008, 00:18
Cool! :) As they wasted a lot of energy IMAO...
Quote Bindibadgi 8th June 2008, 10:10
That's not true - X58 uses MORE power because of the super fast high frequency QPI links. At least, in its current revision it does - this could change.
ssj12 - it's not about Intel Licensing SLI, it's about Nvidia letting Intel license it.
Quote kenco_uk 19th June 2008, 14:51
They did for the 975X - I'm a little surprised that recent Intel mobo's are able to carry Crossfire, but not SLi.
Quote naokaji 19th June 2008, 14:57
It's not a limitation due to Intel, its nvidia not allowing it.
Quote kenco_uk 19th June 2008, 15:03
Aye, I know. bindi said the same a couple of posts above. I'll word my post better for you:
I'm a little surprised that recent Intel mobo's are able to carry Crossfire, but there's no agreement in place for SLi.
