Silverstone develops sideshow device
The Silverstone MFP52 Sideshow device
Sideshow devices have never really taken off – they’ve always seemed to have an inherent inability to offer enough functionality to be actually useful. Silverstones MFP52 should readdress the balance though – it’s a mobile unit with a 1GB capacity and an Nvidia PM2 ARM processor (not the new one unfortunately, that’ll be next year we were told), that also features Bluetooth and USB connectivity.
The MFP52 will sync your Vista sideshow applications and gadgets with the device so you can take it on the move, or use it to control the Windows Media Player 10. The feature we see being particularly appealing though is the Powerpoint viewer where you can scroll onto the next slide to see it before it shows up on your main PC screen/projector, and you can even skip slides without affecting the presentation too.
The MFP52 comes with a 3.5” screen, four way touch pad and enter, back and home buttons, as well as an integrated speaker and microphone for Skype. It even has a headphone-microphone 3.5mm jack so you can use a mobile phone hands-free too.
Lookswise the MFP52 is very, very smart and while it may not be exceptionally ergonomic it’s still lovely to hold and feels like a very well built device – it’s made of a two piece tough polycarbonate and steel chassis. For $250 though, it’ll have niche appeal - which Silverstone admits.
You don't have to have Vista though - you can still use it if you just have Windows Media Player 10 with XP - it simply works by drag and drop and can automatically sync too.
Is sideshow a good idea or too tied down to Microsoft? Let us know your thoughts in the forums.
Silverstone develops sideshow device Silverstone develops sideshow devise
Quote badders 4th June 2008, 09:26
I want a sideshow device. HARD.
Quote Da_Rude_Baboon 4th June 2008, 09:32
Ah!!! That looks absolutely perfect as power point preview screen for our conference suite at work. Any ideas on UK availability and pricing?
Quote Nexxo 4th June 2008, 09:48
Need.
Quote steveo_mcg 4th June 2008, 09:50
What would you use it for?
the royal you that is.
Quote CardJoe 4th June 2008, 09:56
I've never really seen the point personally. It'd be good for presentations, but a smoothly run presentation would render it mostly useless as far as I can see.
Quote samkiller42 4th June 2008, 11:05
Want, just for the sheer fact that i can i suppose.
Sam
Quote Neji 4th June 2008, 11:27
Isn't it 'redress' the balance?
Quote Bindibadgi 4th June 2008, 12:58
Pretty soon after the States I'd imagine, which is within the next month or so. Either that or import it from Europe. He didn't know other prices sorry.
Quote Cthippo 4th June 2008, 19:56
Hmmm, no open source support? Fail.
I could see using something like that as a screen mounted in a case, but otherwise I too am having a hard time seeing what it's useful for.
