Lian Li's Xbox 360 chassis looks like it could be a winner, but there is no word on pricing or availability just yet.
We popped along to see Lian Li this morning and it had one of the more interesting cases that we’ve seen during this year’s Consumer Electronics Show, and this one isn’t for PCs – it’s for Xbox 360 owners.
The company has designed an all aluminium Xbox 360 replacement enclosure that lives up to Lian Li’s reputation for quality and sleek, stylish design. The chassis was a prototype, but it contained a fully-functional Xbox 360 on which I had time to do a quick race in
PGR4.
Of course, you’re going to have to pull your Xbox 360 out of its original case, which means that your warranty will be void. But with that said, Lian Li’s solution is a vast improvement over the Xbox 360 chassis’ cooling, which means that it will be a much quieter design and overheating should be less of an issue as well.
Lian Li’s representatives said that, due to the prototype case’s design, there is the chance for end users to replace the Xbox 360 hard drive with something cheaper and larger too, because Microsoft’s drives aren’t exactly good value for money when it comes to pounds per gigabyte.
This product is by no means final, but Lian Li is hoping to launch it later this year – we’ll bring you more information on the product as and when it becomes available on the market. For now though, we’ll leave you with some pictures that you can discuss
in the forums.
45 Comments
Discuss in the forums Replyso I would just keep it as is rather than risk it.
Do ****ing want.
You might even be able to fit a PC in there, simultaneously.
But i do like!
Doors on PC cases are bad enough, but to have them on your consoles as well? No thanks.
Besides, Lian Li already make a case for my 360. It's called the PC70 and my console sits very nicely on top of it :)
A case like the PC-C30A would better fit in the living room.
think it need something else to be marketable though?
ps2 mouse/ keyboard support would be good, also some tive type remote I woud like. They would need to talk to microsoft though obviously, warrenties are nice too.
I agree that this case seems a little ugly and the door a bit pointless but on the flip side its such a perfect foundation for a good 360 cosmetic mod
The 360 doesn't have PS2 ports, so they'd be a pointless. No idea if USB to PS2 convertors would work, and it would only be for the keyboard anyway.
If you wanted wireless keyboard, you could always get the keyboard add on thing for the controller.
And what warranties? The only one you'll have on the console will be voided as soon as you crack it open to start putting it into the Lian Li case.
Also: What's he yammering about the HDD for?
IIRC there's some fancy trickery that does an absurdly good job of stopping people doing that.
But at least this looks better than that last bunch of LL cases I saw.
the psu isn't inside, you can see the xbox360 power cable from the back photo. and the only probleme is the wifi adapter.
Hey I've got an idea, let's just package it in a mini-fridge and that way we can cool some beverages along with our xbox.
Seriously, I thought this article would be about something in a form factor close to that of the xbox with quieter fans and better airflow.
I thought it Might be good to make a replacement-case that was 42 cm wide (normal hifi-width) so it could be stacked with AV-amp, but this one... Damn.
i might be getting this this christmas
and i'v seen better replacement cases
A: Move the DVD drive
B: Loose the Door
C: Make it large enough for W/C (This would do nicely)
Job Done
Sam
They can't tell if you change the case? And they'll only band you from live if you have a large volume of complaints made against you and/or you have an illegal mod-chip in your unit.
Can't see why (or even know that you've changed cases for that matter).
I like it, but I think the DVD drive should be horizontal and lose the door.
There is a mod for HDD change from HDDHacker, http://www.xbox-scene.com/xbox1data/sep/EEyAZlukkkkGLVUagB.php
I'm thinking watercooling, modding and DVD drive sound proofing :D
