Motherboards not passing EMI tests?
The GA-P35-DS3 is producing 5dB more EMI then the FCC regulations permit.
Motherboard manufacturers are getting a shake up when it comes to Electro Magnetic Interference certifications after a batch of Gigabyte GA-P35-DS3 motherboards failed a recent retest for EMI certification from the FCC and CE.
EMI testing is a requirement of almost all electronic products sold in the US and the UK. Requirements for certification from the FCC and CE vary. The FCC and the CE EMI requirements are as follows:
Motherboards not passing EMI tests? Motherboards are not passing EMI tests
Most electronic devices are designed to fall between these ranges but there's always those few that manage to slip through. Unfortunately for Gigabyte, the GA-P35-DS3 just happened to be one of those that managed to slip through only to be caught red handed on down the road. Three of the motherboards were submitted to the Electronics Testing Center in Taiwan for EMI testing. The results were surprising with three failed tests for EU and Taiwanese certification levels and two failing FCC regulations.
This of course could just be a bad batch of motherboards and the testing papers don't tell just where the motherboards came from. That makes it impossible to tell if they were pre-release testing versions (which sometimes don't meet all certification requirements) or if they were retail models. The Inquirer ran the story initially and got back a very interesting reply from Gigabyte.
Motherboards not passing EMI tests? Motherboards are not passing EMI tests"All GIGABYTE motherboards undergo rigorous and thorough testing (including EMI testing) before being brought to market. Attached is GIGABYTE official certification for the GA-P35-DS3, where it clearly shows the GIGABYTE GA-P35-DS3 passing all EMI requirements.
It seems a little strange that one of our top selling boards just so happened to have a negative report from the Taiwan ETC several months after the launch of the product. Any motherboard manufacturer or anyone else for that matter can pay to have EMI testing done from ETC. In this case, GIGABYTE has contacted ETC and they have confirmed to us that one of our competitors is actually the one who paid for the testing mentioned in the Inquirer article.
Not to impugn the integrity of the ETC, but any time you have research paid for by a competitor of the study's focus, it does beg the question of how accurate the "report" is. In all fairness, the fact that one of our competitor motherboard manufacturers paid for this report should have been mentioned in the article so readers can make up their own minds as to the accuracy. For example, as mentioned in the article, there is no information in the report about where the motherboard tested came from. Was this a sample purchased from a retail outlet? Were there any modifications made to the board before testing?
Clearly, this is a malicious act by a competitor to negatively impact GIGABYTE motherboard sales, and they have used the Inquirer to do so. Hopefully we can get a retraction or at the very least a clarification as the article has been picked up by several other websites and can have a serious negative impact on our motherboard sales
The problem with this reasoning is that both Asus and MSI had boards that were included in the test and their boards passed all certification requirements. So if someone had managed to pay the ETC to fail competitor motherboards, Gigabyte would not have been the only target.
However, it does raise the question of who paid for the testing on these boards? It is quite possible that it wasn't Asus or MSI that paid for the test on Gigabyte's board and could be another competitor in the industry that requested boards from all three manufacturers were tested.
A motherboard itself failing an EMI test is not a cause for concern. A good metal case can negate any EMI being produced by a motherboard with no adverse effects on surround equipment but the regulations are there for a reason. If there were no regulations on the levels of EMI that an electronic device can produce then everything would interfere with everything else. When you're getting into the dozens of electronics devices that run simultaneously in the average household, that could end up being a very big problem.
Discuss in the forums.
10 Comments
Vash-HT 27th September 2007, 20:21 Quote
Isn't this more properly called EMC emissions testing?
On a side note, it would be pretty surprising if it did happen, these cert. places are usually very very thorough when looking at things like this. I wonder if Gigabyte will be audited or investigated on this. Companies sometimes choose a "golden" device for testing such as this, I wonder if they did this the first time around and not the 2nd.
Tyinsar 27th September 2007, 21:09 Quote
This is part of why I prefer cases without windows.
pendragon 27th September 2007, 22:09 Quote
Hmm.. very interesting observation.. I wonder how much effect plexi/acrylic windows actually have on this sort of thing.
Ramble 27th September 2007, 22:10 Quote
Well, you could embed a mesh of thin copper wires into a window (like they have on car windscreens) to make a faraday cage if EMI bothered you THAT much.
GuitarBizarre 27th September 2007, 22:32 Quote
Some people record using their PCs. A high quality condenser mic is very susceptible to EMI interference. Not to mention, even if it didnt come out of the case, the internals would still be affected. Hence EMI is a concern for at least some consumers who use their PCs as audio workstations.
Redbeaver 27th September 2007, 22:33 Quote
LOL!
i bet its DFI thats paying for the test :P
dfrangu 28th September 2007, 07:35 Quote
No, in fact is a company with A... When you feel the competition is becoming too strong, the best thing is to throw a bad light on them... And they managed to do this...
MilkMan5 28th September 2007, 08:41 Quote
Hmmm, it seems to me that you have "hit the nail on the head", so to speak.
" ... It is quite possible that it wasn't Asus or MSI that paid for... "
I wonder what gives people the idea that ASUS or MSI had nothing to do with this!
I’m sure this story will not go away, it will be interesting to see what happens next.
d3fiant 28th September 2007, 08:42 Quote
my old thermaltake skull case had a wire mesh on the window for this exact reason, as for the article, I doubt this is a one off and that these manufacturerws are always trying to get one over the others via what ever means present themselves
Tim S 28th September 2007, 09:01 Quote
IÂ’m sure this story will not go away, it will be interesting to see what happens next.
It's possible that they weren't involved, but they're certainly not ruled out. Think about it... they're all tier 1 mobo makers and someone else is feeling the squeeze because the tier 1 mobo manufacturers are stretching the market with their superior man power/resources in R&D. Whoever is feeling the squeeze gets them all tested and make the one that is causing the biggest headaches look pretty incompetent/bad.
I'm sure the story won't go away too... it'll be interesting to follow.
