AMD is covering all of your bases with quad, triple, and dual-core offerings.
In what could be a brilliant marketing move or a gimmick to some, AMD has revealed a new line of CPUs on its roadmap - triple-core processors. Based off of the Phenom quad-core design, triple-core are set to fill the void between current dual-core and quad-core offerings.
Arriving sometime in the first quarter of 2008, these new processors should be cheaper than their four-cored compatriots while still offering more power than its dual-core siblings. While many applications have still yet to see full support of multi-core CPUs, users will still see an increased performance boost when multitasking.
With our advanced multi-core architecture, AMD is in a unique position to enable a wider range of premium desktop solutions, providing a smarter choice for customers and end users,” said Greg White, vice president and general manager, Desktop Division, AMD. “
This innovation is a direct result of our development of the industry’s first true, native quad-core design, coupled with AMD’s manufacturing flexibility, to create multi-core processors in two, three, and four computational core configurations on a single die of silicon. As a customer-centric company, AMD is committed to working with our OEMs to deliver compelling value propositions across their multi-core product families with capabilities that address their requirements and aspirations.”
While AMD was adamant that there have been no yield problems with its quad-core processors, this introduction may give some proof to there really being one. This part could just be a quad-core CPU that had problems with one of the cores but instead of completely binning the processors, it has disabled the faulty core and labelled it as a triple-core. Even if this is the case, it wouldn't be the first time that a manufacturer has done something like this and it won't be the last.
Will the triple-core offerings end up being like the middle child of a family: often ignored and forgotten about. Or will it really prove to fill the niche between not having the money to spend on a quad-core but still wanting more than a dual-core? Time will tell but come early next year, you can expect a review from us to see if it will suit your needs.
Discuss your thoughts on this new offering over
in the forums or in the comment section below.
17 Comments
Discuss in the forums ReplyDoubtful there was a whole lot of R&D in this one. Celerons were just Pentium parts with half of the L2 cache disabled and that's more then like the same scenario that this is: a faulty core that's been disabled. That'll help AMD save from binning a bunch of parts and give a little bit of a boost to their product lines with an additional option. These triple-core processors might just run slightly better then their quad-core brothers as they'll have all the same resources to share but one core less in the competition.
I guess we'll see come next year though.
This didn't require any R&D. As far as I can see it is just a quad-core with a single core that has been disabled, probably because it was defective. Intel can't do a similar thing due to the way their core-design works. For AMD this is a cheap way of filling a "gap" in the market and using defective quad-cores, without having to sell them as dual-core and incurring a bigger loss.
does this suggest that the quads aren't binning very well?
so if the article is true, maybe we can do a "pencil trick" on triplecore to unlock the 4th one? LOL
Intel hasn't done this because their four core parts are two dual core dies in a single package, so they can independently test each die before packaging them together and only use fully functioning dual core dies to make quad core parts, with the broken dual core dies going to make budget single core parts.
Also, maybe three cores is a sweetspot for some - I regularly run a couple of tasks at once and it would be nice to have headroom for more, but I don't really need four cores. If it was only a little more expensive to get 3 rather than 2 cores, I'd probably be tempted.
Plus they can then start to cut down on the dual core manufacturing more and more. They could even get to a point soon when they dont really need to make dual cores anymore and for the budget processor they can just sell off any defective quads they get, even disabling ones with 2 defective cores and selling them is possible.
I should think it will depend on the developers.
They have to design there program around a choice of paths, eg:
1 thread (won't use extra cores at all)
2 threads (will use exactly 2 cores)
3 threads (will use exactly 3 cores)
4 threads (will use exactly 4 cores)
Multi-threaded (as many cores as are available)
If they choose to use any but the first or the last they also have to do the ones above it in the list or they remove possible users. A fair few companies have gone for dual core support so far and those won't benefit from 3 or 4 cores.
From a user perspective multi-threaded is the most attractive as it will scale with any number of cores now and in the future.
From a company perspective multi-threaded will take the most work to pull off (specific core implementations could be as simple as shunting a given part of the code onto a second core permanently if available, where as multi-threaded requires the program to decide how to do it on the fly) but once they've got a solution that works they should be quite able to re-use it in future.
The way I see it, the more core options we have and are represented in the market, the more likely the devs are to actually go multi-threaded, which will be good for us :)
If this Tricore news came out a month or so after the release of Phenom it would be an easier sell but since the news is only a week after the launch of the 6 months late Barcelona, it must put shivers down the spins of all the major Server OEMs. Barcelona needs to be reliable and with this news following so closely after the launch of Barcelona reliability of the quad core Barcelona will be very much in doubt.
Seems to me that most here believe this is wonderful and do not realize that AMD is dumping the Barcelona reliability problem on the backs of the desktop enthusiast. No wonder Mr Richards quit AMD when he did, he did not want to be the mouth piece of a Barcelona project that has turned sour. I realize GPU companies have released cores that did not function correctly and released them as slower but still functional cores but AMD's announcement must set some kind of speed record for admitting that yields are not what they should have been, beings that AMD does not have a Phenom desktop chip released yet. You do not cut into your own sales of the high end quad core Phenoms pre release, most of the time a company will release the worse chips as slower products such as the 1.9 GHz Barcelona when compared to the 2.0 GHz Barcelona. You do not go out of your way to announce "hey guys, why purchase a quad core that you may have been waiting a year for when we have perfectly good Tricores for you." This kind of news usually comes from the competition and not from the company that has just spent billions upon R&D and fabs to manufacture a Quad core
While it does demonstrate that they are having some yield problems, enough that they will have a decent number of Tri-Core chips to sell. I just don't see how you can presume the latter is also true from this.
