According to Nvidia's partners, the GeForce 8800 Ultra is coming down in price.
During meetings with a number of Nvidia’s partners, we learned that the Santa Clara-based graphics card maker is about to lower the price on its flagship GeForce 8800 Ultra.
Currently the GeForce 8800 Ultra is priced around the 700 Euro (£475) mark with taxes added on, but that is set to drop by around 50 Euros (£35) in the next few weeks.
This should see cards like
EVGA’s e-GeForce 8800 Ultra Superclocked come down to around £500, while standard clocked Ultras will cost as little as £440 – that’s about what the GeForce 8800 GTX cost at launch.
Speaking of the GTX, if that stays at the same price as it is now, the difference in price between cards like
EVGA’s 8800 GTX KO Superclocked and the standard 8800 Ultras will be as little as £25. That’s far more in line with where it should be, in our opinion.
If and when this price change goes through, there is also likely to be more pressure on AMD, because Nvidia has no competition at the high-end. With Nvidia lowering prices, the more expensive alternatives to the
ATI Radeon HD 2900 XT start to look a lot more attractive, especially for those with 24” and 30” widescreen monitors.
Discuss in the forums.
13 Comments
Discuss in the forums Reply- Cars
- Dates
- PC stuff
I can not complain about anything getting cheaper unless i am trying to resell it, :DHmm...as I understand it, the Ultra is already more energy efficient than the standard GTX -- I think, even at its higher stock clock speeds, the Ultra is supposed to use about 1 Watt less than the stock GTX under load.
So...I wonder how much power you could save if you UNDERclocked an Ultra down to (or below) GTX frequencies (so it'd draw even less power). Of course, then you'd be paying more for a slower card...but you'd be saving power, if that's worth a premium to you...
I
m pretty sure they've been behind since the 6600gt. 6600gt was the greatest mid range card IMO.
how about a fantastic Gforce 9800 card that consumes *gasp* 42 watts on load and rapes the 8800 and costs about 350$?
power saving?
yes
powerful?
yes
ideal?
yes
would rape ATI/AMD?
maybe, why? and if ATI/AMD make this sooner as a X3800XXXX?
