Thermaltake DUOrb: Two is better than one, as they say.
Are you surprised by the arrival of even larger cooler? Me neither. But how does a 30cm fan on a huge heatpiped cooler sound? Impressive or just seriously crazy?
We checked out a lot of Orbs from Thermaltake previously at CeBit, however this time on stand was a DUOrb GPU cooler, with two fans and dual heatpipes. It's very similar to Zalman's VF-series GPU coolers, but this comes with "twice" the cooling.
Scythe had a concept
30cm CPU fan and heatsink on display. This beast of a cooler contained no less than
ten heatpipes in its massive fin array.
The Scythe Zipang has one of the largest CPU fans we've seen at 14.5cm, which should supply some superior cooling with less noise. It's compatible with 12cm fans if you have your favourite you can't do without, although at 1000RPM and 21dB supplying over 81CFM of airflow, the included one will beat many other fan's ability to cool.
The Scythe Kodachi is a northbridge cooler with 10.5cm fan attached to a large, dual heatpiped fin array. No weight was given, but even though it's an all aluminium design it has a high centre of gravity which could push the two included push pins to their limits, especially when mounted in a case and at 90 degrees to the ground.
Finally, the Ninja CU is a Special Edition cooler that's been pending a few years. Scythe were concerned that the near kilogram weight would buckle some motherboards, however it finally caved to the calls from the Internets for a copper model. It'll only be arriving in limited supply, so when it's available, grab one quick if you've been waiting for it.
With heatsinks like this, could it spell the end of anything but the most expensive watercooling? Discuss
in the forums.
10 Comments
Discuss in the forums ReplyI think these are totally unecessary, and are marketed as widgets to give you bragging rights.
So there.
-monkey
Then came the ccfl mania. Cases stuffed with all those kitchy light kits. blinking, rolling or collorchanging.
Then came the copper is better cooling mania. Copper heatsinks the size of a car was the bomb. Although not cooling a few degrees more then standard cooling.
Then came the Silent mania. With copperfins in all sorts of shapes, from umbrella likes to vortex shaped fins.
Then came the Heatpipe mania. Heatpipe was the new kid and everything went over the top from there. Heatsinks with one, two, six, and even 10 pipes on the cpu heatsink. But that did not stop there. All of a sudden copper heatpipes where on every motherboard. And even those gets extremer to rollercoaster like shapes and bends.
But hold on! We got something new here!. Now we combine heatpipes with giant radiator like fins. And then we ad some more and bigger fans to it!
I wonder why the copperprices wend skyhigh the last couple of years. Over here even the thiefes are seeing $$$ in copper. They even starting to steal whole copper lighting railes and steal even the copper lines that power the trains! And pulling kilometers of copper wire out of the ground.
Also it is a waste of resources. Anybodie 'knows' that this is not the right way to go. We have to fight the source of the problem. The devices that generated the heat. There comes a time that the biggest heatsink in the world can not cool a processor anymore with the wattage increase this going. Not to mention the ridiculus psu wattages. I can not imagine that in 2 years every houshold computer is running a 2000watt 24/7. Dont they know what this is going to do to the powergrid and enviroment.
Its totaly insane!
Any heatsink and fan that could possibly cool a cpu near-silently without the risk of splashing liquid anywhere but getting near to the cooling properties of water is a good idea in my book.
During a heavy load, such as rendering video, the CPU gets up to about 50C. Again, this is with the stock heatsink and 60mm fan.
Is it really necessary to have a heatsink that big? Do we really need huge fans? With proper implementation, you can use an older Scythe Ninja with a single 120mm fan to keep things pretty darn cool.
I thought about investing in a watercooling setup, but after my research I'm left to believe that air cooling already has reached the point where it's pretty effective. Sure, it might not cool as well as water; however, as long as my components don't overheat, and as long as I can keep things running at near silence, then watercooling remains a geek-factor thing.
-monkey
For water colling you have the problem of refilling your expensive (on my tastes) liquid, chances of leakage, and water cooling pump motor noise, and fan noise for some water colling setup.
Also, for people that never installed a water cooling system in there life, and know nobody else that has a water cooling system, it can get very complicated to setup. (eg: what to wire what first)
