The Antec P182 was one of our favourite cases and already Antec has announced a larger P180-inspired design, the P190.
Antec has today announced a new case, the P190, which is based around the same design principles it followed for the outstanding
P182 we recently reviewed.
The P190's design was fuelled by the company's new dual power supply system called the 1200 Watt Neo-link, which combines a 650W and a 550W PSU together. The new power system is aimed at supplying multiple graphics cards and multi-core CPUs with enough power.
The P190 also incorporates some truly brilliant cooling measures. With a 200mm 'Big Boy' fan, Antec's largest fan yet, in the side as well as two top-mounted 140mm fans and a rear mounted 120mm as well the case should be the only thing on the planet cooler than we are, whilst still being smaller than our egos.
The Antec P190 will be use air filters and dual-layer side panels to deaden the sound of the fans and the system inside. If it holds up half as well as the P182 did in our testing, then it'll be another case to be very proud of.
Another improvement over the Antec P180 line is the relocation of the motherboard tray which has been shifted to reduce cable clutter, and there is also support for externally mounted water cooling.
Cautious readers need not worry though as there is a sample on the way to the
bit-tech offices for a full workout. We'll be sure to give it some thorough testing.
What case do you use at home and what do you look for when buying a new chassis? Tell us
in the forums.
16 Comments
Discuss in the forums Replyand wow lots of fan s there...
hopefully will be as good as the p182 and p180
The p182 should be my next case, this beast just looks too... huge. And the price, oh the price. £290 with two PSUs isn't that bad though, if you're paying about £55 for a PSU, it means the case is £180. Now compare that to a big Lian-Li. However, I'd like to see these PSUs tested first.
ONLY £247 at OCUK. I'd rather have a £100 case and a £145 PSU.
That said, I'd still rather have a V-1000.
go antec!
Does this mean we can expect yet another p180 price drop :D
oh and anyone gunna review the new Antec Sonata III??
there are like 3 i think, 1 for 1x psu and 2x 80mm fan, and 2 for dual PSU's (which aren't standardised i think ... sigh)
dual psus will take some space away for bottom 120.2 rads : /
i love my p180b but frankly, it was quite a hassle to watercool and cable management is a bit of a problem.
