Dell received over 11,000 votes calling for XP to represented in their home pc and notebook range
It doesn't look like it's been going well for Windows Vista so far, not only has
it suffered from poor sales in China, but it now appears that XP is the preferred OS for the majority of Dell PC customers.
At the end of March there were only two home PC models sold by Dell that still came with Windows XP pre-installed, the vast majority of home PCs and notebooks having made the switch to Windows Vista.
However
Dell's Ideastorm website, designed as a method for customers to give feedback, was soon flooded with over 11,000 votes for Dell to once more offer XP on home PCs and notebooks.
The company promptly responded, announcing on their website that;
""We heard you loud and clear on bringing the Windows XP option back to our Dell consumer PC offerings,"
Dell now offers a selection of six home PCs that come with XP Home or Professional pre-installed and the move has been widely praised by users who prefer Windows XP.
Previously over 100,000 people voted for desktop and notebook PCs with Linux OS preinstalled and Dell was
quick to respond in a similar manner.
Given the choice, would you choose Windows XP, Windows Vista or Linux for your Dell?
Cast your vote in our Forum.
57 Comments
Discuss in the forums Replyhaving played with vista in a VM for a bit the only thing that i really really dislike is the new explorer
i think its horrible and a far worse file manager than the old XP explorer
i dislike what they've done with some of the configuration options too (notably network connection config and display properties) but i can live with those being different as i dont have to change them very often
explorer is something i use all the time
I guess this goes back to the first days of XP.
I was/am in the boat that refused to switch from Win2k. I only use XP on this laptop because it came with it. And yes, the first thing I did was shut off all the bells and whistles and switch back to classic everything.
Give me win 3.1 that actually works. (:Ug: change is bad. :grunt:)
Not having tried Vista, I guess my opinion doesn't mean anything.
Plus the fact that I'll probably never buy a Dell.
That being said, I don't need DX10 for anything, so I'd sooner switch to Linux than Vista.
I think Vista is too power hungry to work well on a laptop.
I fail to see how Vista is a change for the better? Microsoft seem to have spent most of the development time building in restrictive DRM, tacking on useless user security features (UAC anyone?) and writing a slug of a GUI.
building in "restrictive" drm? that was hollywoods fault, and , look at iTunes and iPods.. DRM anyone?!?!?
UAC is not useless, how is it useless? It gets abused by companies that can not right GOOD software, that is NOT MS's fault. I assume you run linux? if not, there is a command called sudo (that lets you run an app as root) -- if every app in linux that you downloaded needed you to do that, would sudo be a useless command?
The GUI is fine? You need a good gfx card, just like you do for beril (sp?) etc on linux.. you needed a "good" gfx card for the XP gui as well when it came out...
It is all change, I do not see what is wrong with it...
What Buzzons said.
But also, the memory management has been a major gripe of mine for ages. I want my RAM to be used not ignored.
sounds like your getting a little cockney over there. us
dell users don't have to play a game on vista to know
its not working so well that info is all over the web that is if us dell users can read!!
they re-wire their power supplies and connectors, making upgrades a chore, and often lock out the out of many crucial BIOS settings. (on my older dimension I can't even set the AGP ap to 4x even though the board is capable of it)
they also rewire the motherboard headers. :(
There are a raft of known driver problems with Vista and it is even more of a resource hog than XP, which was even more of a resource hog than 2000. I rely on Windows PCs to make a living, so really, I have absolutely no reason to go elsewhere until something like After Effects requires it (I only went to XP because Adobe Premiere insisted I did).
So frankly, why the hell would I want to go anywhere near Vista? What would the advantage be? Lots of instability and bug issues.
Screw this noise, I'll wait for SP1.
At the moment no-one wants to spend the resource to invest in vista because there isn't market penetration. Dell get most PCs to end users and businesses!
I have vista on both my main room system, and my laptop. Not run into a single problem yet (no firewall/AV installed either). Rather I've had nothing but good times with it. Not even a single BSOD, crash, or freeze, despite having both computers on almost 24/7. Hell, my lappy even gets better battery life!
So here is one very strange idea that you lot should attempt: USE THE OS BEFORE BASHING IT.
Thanks.
edit: wait maybe for the win -> "***" was censored
edit2: yep.
QFT!
The only time I got BSODs on Vista was when I was overclocking due to the enhanced memory management proving my RAM wasn't up to the job. Runs faster though then when it was overclocked on XP.
I did at a lan on someone else's pc, it was the worst os I have ever used ever, worse even than the faux 32bit crashathon that was windows 95a, at least windows 95 didn't display 3 warnings per operation and ran much faster on hardware about 50x slower.
Yes it is going to change for the worse and i got a couple of BSOD before i was able to fix it the only problem i have was when i run window's media center and when i quit it it alway's give me the BSOD. and last not all games is Vista capable they should push all games to be Vista capable that's the problem when they going to intorduce a new technology and going to discontinue the technology with out giving time for us to readjust and many people perfer XP, Next there going to spend like 160.00 *more popular* just to update the O.S So they won't be "behind technology" :'( :'(
I have already built about 15 vista systems for other people on campus, and when memory is bad, it BSODs with a mem error..
when I use XP on the same system, it runs fine until that mem sector is utilized.
this actually points to a better OS, because it recognizes faults before they become lost work.
Vista has been out for 6 months now and if you include the RC's then it's been about 9-10 months. there are still no really good drivers for nvidia (And I won't even bother mentioning the POS that creative puts out). Any app compatibility issues still haven't been patched up.
That's pretty disgusting to me, and as a result, I will never buy another Creative sound card (The hardware isn't bad though).
Only driver I've had issues with were earlier nVidia drivers, and belkin drivers, so I used a alternative wifi driver, and stuck with WDDM till the dirver i'm using now came out, and now life is good..
@ramble - the above is why creative is having such a problem with it, the Alchemy project as made some success in re-activating hardware acceleration but really the entire architecture of soundcards has to be rethought.
keep a very close eye on how much RAM the OS uses depending on applications, when in an idle (no programs running) it will still read that the mem is being used by the OS (good) but when you activate a program the OS will release most of the mem it's using to that application. Remember, you bought the RAM for a reason.
RTFT
Sorry it has to do with the thread?
After all you don't buy a double bed and sleep in one corner in the foetal position.
And when you have 2 gigs of ram, games shouldn't run like crap.
That's non-optimized drivers from manufacturers. Microsoft has given plenty of time for manufacturers to sort their arses out.
I said when mem is faulty, unless you're openly admitting you have mem with a faulty sector, which destroys any argument against vista you might make.
I have a 4300 I got a while ago, and it will not play BF2 in any way, shape or form. BFV works, but forget about BF2 and that is with 2 GB RAM, 7600GS, and P4 Willamette 1.6
[as a side note, its interesting the leading response in the poll is "wouldn't buy a dell"]
DFI-Ultra-D
7600gt.
2gigs OCZ
I think my pc runs bf2 just fine.... At elast in XP.
it should of been {Other OEM PC with vista / Other OEM PC with XP}
as other to options as saying {Wouldn't buy a Dell} as an vote (alot in here would probly not buy an dell any way)
However good Vista is, it needs the hardware and software support before a business will adpot it. For one thing in my office we use AutoCAD 2006, which won't even run on Vista! Regardless of who's fault the lack of support is, if there are still compatability problems then it doesn't make sense to upgrade until it's sorted out.
Because noone who knows anything about computers will ever buy the crap they try to sell (no, not only true for dell)....
proprietary connectors and form factors to prevent upgrading....
unbalanced components...
rip off prices....
special no overclocking option bios versions....
a common complaint, and for the moment, I agree. this can be likewise attributed to poorly written drivers not making efficient use of the hardware, but that will get better with time.
However, I recently purchased 4 desktops from Dell Small Business for a new charity (40% discount. ) and chose Windows XP Professional over Vista Business as the OS. I believe Vista is too new and there isn't sufficient support. In a business environment (and as an inexperienced server admin) I'd much rather know that someone else has probably come across this problem and posted a solution, than to come across a new problem and try to solve it myself.
One Sony, one Acer, I'll talk about the sony here.
Hardware: Drivers are a problem.
Analogue modem? doesn't work (yes there are people living in no broadband area's) ;-)
Soundcard? Well it does stereo (and yes it should be more)
7-1 Cardreader, well some cards aktually work! Most don't.
Software: No Updates
Burn-Program? (1 year old) doesn't work, no update, why don't you buy a new one?
Paint program? (1 year old) doesn't work, no update, why don't you buy a new one?
Photoeditor (Expensive! 1 year old) doesn't work, no update, why don't you buy a new one?
So he tries to go Dualboot...on new Lappies you get no installcd, not even a recoverydisk, it's all on a special partition somewhere on the harddrive. As soon as he puts on a Bootchanger, the entire thing reinstalls itself.
Switching to XP means losing a legal copy of Vista, because it keeps reinstalling itself until beeing deleted completely, and you get no copy on a disk.
Updates are a pain in the @rse (although this is mainly due to the analogue modem not working right) :)
So for me? I'll wait for the SP1, until then XP is something that has matured to a point that it will just...errr.. work?
Xir
