Gratuitous Naked Penryn Die Shots
Wouldn't you just love one for your wall? Intel shows off 300mm wafer of 45nm Penryn dies
IDF SPRING 2007 OK, OK, here it is and it's just what you wanted: gratuitously naked Penryn Sex Die Shots.
It's a 300mm wafer that provides a really cool light splitting, rainbow effect. Also, there are some photos of it being held up by important Intel people, Mooly Eden and Pat Gelsinger.
Penryn is the new 45nm processor from Intel, and this is the first public showing of the new process that was announced in February, so enjoy!
Feeling better now? Don't give us the details in the forums, please!
17 Comments
DougEdey 17th April 2007, 08:24 Quote
So that's a good few thousand dollars dead right ther.
L2wis 17th April 2007, 09:01 Quote
lol, better if there was a shot of it smashed on the floor.
mmorgue 17th April 2007, 10:12 Quote
It's neat and all, but uh.. nothing I can do with that pretty coloured wafer of silicon. I'll get moist when it's in a nicely boxed package with my delivery address on it!
However I am sure there are those who will be replying to the article with one hand only.. ;)
_DTM2000_ 17th April 2007, 10:23 Quote
One handed people? ;)
Bindibadgi 17th April 2007, 12:25 Quote
Well I get to play with one tomorrow. :D:D /note to self, don't wear tight underwear.
mmorgue 17th April 2007, 12:41 Quote
^^^ doh!
/curse you lucky people! ;)
Hamish 17th April 2007, 12:43 Quote
why do they use round wafers? wouldnt it be less wasteful to use square ones?
Munterofamodder 17th April 2007, 12:49 Quote
Its a little bit tricky to grow cuboid ingots...
DougEdey 17th April 2007, 13:04 Quote
4-storey MEGA WEDGIE!
Hamish 17th April 2007, 13:05 Quote
care to elaborate? i dont really know anything about cpu manufacturing other than small nm = good :p
kenco_uk 17th April 2007, 13:06 Quote
Say what now?
You mean cpu's are grown to order?
DougEdey 17th April 2007, 13:08 Quote
Silicon is a crystal, it's grown to a wafer.
Hamish 17th April 2007, 13:13 Quote
http://en.wikipedia.org/wiki/Czochralski_process
k so its basicaly cos they have to rotate the thingy to get a solid crystal, squares are a bit hard to rotate properly like that :p
Tim S 17th April 2007, 14:56 Quote
yes, it's to do with the way single crystal Silicon is "grown". They use the same technique for the materials used in aircraft engines, as impurities mean a potentially lower melting point in that particular scenario.
kenco_uk 17th April 2007, 16:24 Quote
Well, blimey. Every day is an education. Is there a theory about that a particular place on a wafer always produces the best dies?
devdevil85 17th April 2007, 16:50 Quote
That's kind of like the glass needed for Optical Cable. The more expensive the cable, the closer the glass fibers were to the center of the sheet, or so you'd expect.
Firehed 18th April 2007, 00:36 Quote
Well towards the edges tend to be somewhat worse. Back when my dad was engineering stuff along those lines, I actually tossed in a solution that helped fix their problematic data quite a bit.
There's a little alignment notch at one point along the edge. Err, not point as it's a circle... but you know what I mean. Anyways, as it turns out, the tiny amount of extra surface area you get along the edge because of that can really screw with heat uniformity data. Toss that point (and, more likely than not, the chip that would be built there), and the data gets a surprising amount better.
It's true for the whole edge area (it adds something like 900mm^2), so the edge will cool slightly faster, and as a result might not always have as good of a yield. As dies get smaller though, we can fit more chips per wafer and help counteract this.
