With VESA's approval of DisplayPort 1.1, could this finally be the replacement for DVI and VGA?
The Video Electronics Standards Association (VESA) has approved version 1.1 of the DisplayPort interface for use in flat panel displays, projectors, PCs and CE devices.
With it comes significant benefits such as a much smaller form factor – making it laptop friendly, low voltage and low power operation, two way display connectivity, optional audio support and higher performance than dual link DVI at 10.8Gbps.
Furthermore Hollywood can back the standard too since it is compatible with High Bandwidth Digital Content Protection (HDCP) version 1.3 making it HD DVD and Blu-ray friendly.
"The benefits of version 1.1 are significant, and will encourage adoption of DisplayPort in new generations of computers and consumer electronics equipment," said Bill Lempesis, VESA executive director.
"Our task groups and committees within VESA worked very hard to ensure that DisplayPort 1.1 satisfies the important objectives it is designed for, and as a result, this new version has widespread support among all the leading computer and consumer electronics suppliers."
Lempesis positive outlook apart however perhaps the most important aspect in the widespread adoption of DisplayPort 1.1 is that it comes royalty free and is an open and extensible standard. This is in stark control to HDMI which carries significant fees (hence the low number of ports in early/cheap HDTVs).
So will DisplayPort 1.1 signal the death of DVI, VGA and even HDMI? In a word: No. DVI probably and VGA yes (eventually) but HDMI is so heavily integrated into the multimedia world and is still such a new standard that it will be nigh on impossible to tear it out so soon.
Personally, I would expect to see DisplayPort 1.1 infiltrate the computer space heavily over the next 12-to-18 months and become the preferable connection option over DVI, VGA and HDMI but as far as your home cinema goes it is likely to have to settle for second billing.
Are the days of DVI and VGA numbered? Share your thoughts
in the forums.
25 Comments
Discuss in the forums Replyvga yes.. dvi no...
i bet graphicscards will have one displayport 1.1 and a dvi port in the future...
</display whore>
Dont really see the need for higher resolutions than those supported by Dual-Link DVI which this will support - but there is always someone out there who wants more.
Question: What is the best way to get both the video an audio from the computer (assuming it has a DP1.1 port) to the Display (the Moniter/Projector/Plasma) and also to your Surround Sound System (Receiver) with only one direct path?
My guess is that you would have to take the cable from the back of the video card to the receiver and have a DP1.1 port on the receiver (which would take care of the audio) and then from the back of the receiver to the Display. Am I right? Basically it's the same for HDMI I would expect.
I agree
In my setup, the weight of the cables puts a great strain on the sockets on the back of my gfx card, so I would love something that would fix this (they are currently supported with electrical tape)
probable list:
VGA
DVI
DP
Component
HDMI
at least we can hope that they include some sort of split-screen/switching in the panels.
The BenQ 24" is a perfect current-day example of this
Look, the plug is design to hold that weight, else stop buying crazy products.
In My opinion, it is just some crappy thing so that when you buy a new video card, and you came home, you realize that it doesn't fix because, it takes a new plug. So you change your mobo, so that means a new CPU, new RAM type, and oh look a new SATA cable, so you need to change your HDD. Moreover, the Mobo take a new power plug, so you need to change the PSU. Then guess what, the PSU doesn't fit in your case, so you need a new case, and finally when you thing you can save your IDE Optical drive.... no they decided to not have that plug anymore on the mobo... and guess what.. the only device you can plug to have an optical drive is this Blu-ray/HDDVD/DVD/CD combo reader/burner...
In other words, you just purchased a new computer...
Ok I TOTALLY exaggerated, but you get my point.
the only way such a thing would happen is if you were using a computer made around 2001 and wanted to put an SATA HDD and a DP card in it. (the DP card wouldn't be an issue if an AGP vers is made)
New Xbox360 with Display Port support!
New PS3 with Display Port support!
-CollinstheClown
only problem now is the $50USD they will charge for a 6' cable
Damnit, I will have to play UT3 on a sh*tty LCD and destroy my eyes more and more each games......
EDIT: oh crap hahaha
sorry about uping that topic , I clicked on a link to the news while reading the Samsung LCD news....
my mistake ;)
DisplayPort offer a few advantage, and one of them not mentioned much is the support of optical cable. HDMI current have problems with low quality cable as well as Cable length. DisplayPort solve all of that.
And DisplayPort 2.0 should double the bandwidth allowed in current spec.
Personally i think DisplayPort is a much better technology then HDMI.
I'll keep waiting for my 30" WQUXGA monitor then ;)
