"Buy me, I'm obsolete!" -- current Blu-ray players may be out of date before too long.
So how many of you are excited over a nice, new, shiny Blu-ray player sitting underneath your HDTV? If you have your hand up, you may want to sit down, as this news may not be good for you. The
Blu-Ray standard is already being revised, and it's likely to make many current players obsolete.
The change is actually in a new feature called "Blu-ray Java," which is exactly what it sounds like. Blu-ray discs will get the Sun-designed language as a programming medium, allowing complex menus and setups for picture-in-picture commentary and special features. In order to allow for this, the Blu-ray Disc association has mandated that players must comply with new hardware and firmware rules that can decode the language, something that current players just can't do.
Though this doesn't sound like a grand revision, it could have some startlingly large consequences. Movies that carry the new feature (which is mandated to be in service by October 31, 2007) may have very limited playback on older machines, if they even work at all. And since current-gen machines were retailing for $1,000 USD, it could mean some
very unhappy early adopters.
Odds are that any machines that can have a firmware update may be able to comply with the new specifications, even if they don't adhere to them perfectly hardware-wise. Of course, LG's Blu-ray/HD-DVD combo drives and the PlayStation 3 will have little problem at all. Since one is attached to a computer and the other is one on its own, neither should prevent an update.
Speculation is that the update won't make old players unable to view future movies, it will just greatly hinder the ability to make use of any special features. However, one never really knows what the future holds, particularly since the new standard will arrive so quickly and Blu-ray is still a very fledgeling format. Since the market is so new, there's no guarantee that movie makers won't start planning to use the features more extensively, given the design will be standard by October.
Do you have a thought on the format change? Or are you like me and think they should have had these ducks in a row before the first $1,000 unit hit the shelves? Tell us about it
in our forums.
23 Comments
Discuss in the forums ReplyPS3 is surely in many more homes than all other BR players put together, and as you say, it shouldn't have a problem with BR Java.
However, there's always a risk with early adoption - together with inflated costs, it's the price of having the latest tech before anyone else.
How I love RvB :D
Rgr that!
Ah, perhaps this bit from High-Def Digest could explain it somewhat:
Because the HDDVD group is a charity that spends all profits on feeding Africa.....
Get a grip mate.
Take it in context.
As for the HDDVD group - All their products work and have been decent. Their discs are region free and have no compatibility problems with current players. Early adopters of the format have not been shafted.
Idiotic replies like the above quoted one are not conductive to a good discussion.
Alot easier playing movies through my pc than through an external player
If you want a cheap drive theres always the xbox 360 HD DVD add on works via usb or can be converted to 5 1/2in drive
Then why state such a daft and none-too-subtle Sony bash then?
It's only a format.....although it does look like BR will win ;)
Because I am not happy with how the Blu-Ray group are handling things. The major player in that being Sony.
HD-DVD is still leading in Europe and hopefully it will stay that way. I dont want region coding shoved down my throat. I prefer to have region-free standalone players allowing me to play whatever discs I choose to buy.
